Looking for a good machine shop Denver, CO. area?
I have an 85' 250 460 4sd 4x4 and need the engin rebuilt. I will do the pulling if they will do the machining. Anybody have a good one to go to and get a quote. I saw a thread on this all ready but it is 5 years old. It can be outside of Denver to. Thanks for the help. This site
I'd be interested in similar recommendations in the Denver metro area, I have an
81 400 I'm considering having some things done to (hopefully just cam bearings but we'll see). -ct |
I VERY HIGHLY recommend Romeys automotive machining, 303-629-0561. They are at 859 north federal, in denver. These are the guys who built the 400 in my truck and that engine has taken way more abuse than i ever imagined it could, and still does not miss a lick. They have also done quite a few engines for my friends (racing buddies) anything from OEM rebuilds to very high performance engines. Just let them know that John from Georgetown sent you down there and they will take good care of you, just like they do with all of their good customers.
Hey, ct, if you have the engine that far apart (cam bearings) you might aswell have everything machined and the heads freshened up.
Originally Posted by Colo79Ford
(Post 6147527)
1981 F350 400 4x4 T18 4.10 31" tires Holley 4412 2V headers true duals. No idea of true mileage, odo reads 94k but the title says 0 so I have no idea if the odo has rolled over perhaps N number of times + the PO had it only for a year or so (bought it from his boss, it spent its life as a Farm Truck in Ft. Lupton) and didn't know much about it. All the emissions controls have been removed/disabled, it passes the sniff test using VERY fine tweaking of the carb + creating an intentional vacuum leak. (This is a different story, maybe I'll explain more later.) This thing has allegedly been rebuilt once supposedly by a reputable shop in Denver but that was two owners + an unknown number of miles ago. Oil (20W50) pressure is approx 35 at hot idle, approx 60-65 when moving. Vacuum is 16 in & steady. All cylinders have 140-150 psi compression EXCEPT FOR #1 which has 130 BUT it goes up the same 10-15 lbs. after adding oil that the others do. This project began as installing a 4V carb - 670CFM Holley Truck Avenger, Eddy Performer 400 EGR manifold; these are parts that I acquired over the past year. Last Fall it began blowing blue smoke for a few minutes on startup, I don't like that. When I replaced the clutch & installed headers last Fall I found a LOT more black gunk in the #4 exhaust port than any others + the #4 plug had a lot of black buildup on it. I'm not sure if it's oil or gas or what, it could very well be from an ignition problem to that cylinder. So, taking the heads off and having them redone (assuming valve guide seal problem here, perhaps the guides themselves) isn't *that much* more work once the intake manifold is off. When the crankcase filled with gasoline last Winter (https://www.ford-trucks.com/forums/7...ml) I took the opportunity to stick my finger in the hole in the timing chain cover and found that I need a timing chain pretty badly, it felt like there was at least 3/4 of an inch of slop there (which makes me wonder how many miles have been put on the thing since it was last rebuilt). So, now the top AND the front have to come off. After last Winter's episode, it's kinda lookin' like an oil pan gasket is now in order, too. Which is a great time to replace the rear main seal. At which point it's probably easiest to just take the engine out and take it apart all over the garage floor. Which is a great time to replace the input & output shaft seals on the tranny, I guess. I put less than 1,000 miles per year on the thing and use it mostly for hauling trailers full of firewood in the winter; mostly along the front range area but I sometimes cut & haul back to Denver the black stuff from the Hayman burn area up near Conifer. What I'm really hoping for is to not have to do anything to the bottom end, mostly because I'm afraid of the expense + it's probably already been bored once and .060 over is too much for this engine IMHO. Since it needs a timing chain, this might be a great time to install one at 0deg offset (instead of 4deg retarded) and, ideally, a new cam. Since I'm doing the heads, the lifters & springs & whatnot would be part of it. I'm kinda looking forward to doing it myself so I can learn something about it; my father used to build stock car engines in the 60s & 70s and he knows a fair amount of this stuff and will help but I've never done it (although I just recently got a copy of the Tom Monroe book + my brother is pretty good at this stuff). The first questions are:
So, whatya think? I don't dare try and post all that at once to the 335 forum, it's too long and nobody would read it (much less answer). -chris P.S. Thanks for the recommendations for the shop on Federal!!! |
Drive Train Industries - near Washinton and I70
I was suprised no one mentioned Blue Oval in Englewood great with Fords. Split Fire off of 64th and Federal is good with performance machining.
X2!
MPG head service is another shop that has been recomended to me, although pricey. I've heard some not so impressive things about Romey's since the kids took it over. Rob McQ will be getting the FE work I need to farm out. I have yet to hear a harsh comment about the guy or his work. |
Originally Posted by Hypoid
(Post 7170334)
X2!
MPG head service is another shop that has been recomended to me, although pricey. Rob McQ will be getting the FE work I need to farm out. I have yet to hear a harsh comment about the guy or his work. --Mike |
I have had some pretty serious issues with using MPG. I am talking blown engines that run for 2 minutes and heads that are not water tight.
Yea, Blue Oval built my 410, it kicks a$$. Rob's a good guy but I had a little trouble with him getting all the bugs worked out.
Originally Posted by DarkWolf40
(Post 7377174)
Blue Oval Performance Engineering:-X22 3761 South Kalamath Street, Englewood, CO (303) 762-8298 @DarkWolf, I'd really like to know more about yours. (I haven't got mine back yet.) |
Wow, this thread is 3 years old.
I know a lot of big power Racers that go with MPG Heads and I know Scott does top notch work there. He still has my 429 down there waiting for my big paycheck to come in. :-X16
Rob at Blue Oval has also done some great work for a lot of folks as well. I just had the guys at AMS automotive machine Balance my flywheel for my F250 and it was affordable and reasonable, they also build a lot of the Drag racers engines. AMS Automotive Machine - Engine Builder, Engine Rebuilder, Race Engines |
I've used Blue Oval and MPG as well.
Also - G&S in Littleton - on Platte Canyon. Also - quick/minor thread jack. Shawn? From CDR? |
