Oil Pan Torque Specs
Can someone with the Shop Manuals for an 89 F250 help me out? I need the torque specs for the oil pan, as in how many ft/lbs and the proper sequence for torquing the bolts. I need to replace my pan gasket and my Haynes manual does not have this information. Here's what I have:
1989 F250 4X4, 5.0l, neoprene one piece gasket. If you need anymore info, please let me know. Thank you. Roger Lane Test Analyst Sr. Automated Test Engineer IBP, Inc. Roger.Lane@ibpinc.com |
Hi Roger
Condensed information from a Haynes Manual Oil pan bolts: 1/4" bolt - 84 to 108 in-lbs 5/16" bolt - 108 to 132 in-lbs Apply a thin even coat of RTV sealant to both sides of the gaskets and a small amount of RTV sealant at each mating joint. (Later models use a one piece gasket.) Tighten the bolts starting from the center, and working out in each direction. Cheers Davie Vancouver BC. |
