GM releases details on upcoming Duramax 4.5L diesel
310 hp and 510 ft lbs. what was the expected hp and ft lbs. of the 4.4L from Ford. |
I don't think Ford has released final hp & tq numbers yet and I highly doubt Ford even knows as of now what the final numbers will be. I honestly wouldn't touch one of the 4.4l or 6.7l diesels that are coming out in 2010 at least until 2 years after they are released. Fords building these engines in their new plant and there are new emmision standards for 2010. I'll keep my truck. Those are impressive numbers though from the Chevy 4.5l diesel.
Wow, GM isnt screwing around, those are some awesome specs.
I dont get why Ford and Chevy is going down in size of liters on there diesels and Dodge keeps bumping the size of there diesels.
These are diesels for the 1/2 tons ;)
4.4 Ford diesel 9% more HP & 15 % more torque than a 5.4 gas? I don't think that compares even close to the Chevy 4.5 diesel spec does it?
Ford better match or get friggin close to the Chevy power wise.........if they don't they might as well not even bother.
We have no clue, because we don't know how much the next 5.4L will be making, so I assume it will be really close with more horsepower.
Originally Posted by dkf
(Post 6152648)
Ford must have a bunch of idiots designing their engines. |
Originally Posted by excaliber551
(Post 6181590)
I doubt they'll even try. Look at the 5.4. They've been building it for years and it's still the most underpowered poor performing engine in it's class.
Damn straight, glad to see i am not the only one that thinks this way. |
Originally Posted by builtfordtough13
(Post 6119967)
Sure, it still has the same semi-floating rear axles as every half ton out there but it's got enough torque to haul 6000 lb. in the bed and 20K lbs. on a trailer....."properly equipped" of course. |
Aleast it will have enough hp to pull 10,500 pounds up a hill decent. Hopefully it will have 2 modes, an economy, and a tow/performance mode. That would be awesome.
Originally Posted by cleatus12r
(Post 6182395)
I think a power loaded diesel in a 1/2 ton will be the best thing sinced slice bread. Do guys know how many people had to jump up to a 3/4 ton just to pull their camper safely a couple times a year? And why wouldn't you want 25% better mileage? I wouldn't worry to much about the powertrain - GM has been ahead in the that dept. since the inception of the D/A combo.
