Ford Truck Enthusiasts Forums
-   Bio-diesel, Propane & Alternative Diesel Engine Fuels (https://www.ford-trucks.com/forums/forum168/)
-   -   What is there for gas Engines? (https://www.ford-trucks.com/forums/737794-what-is-there-for-gas-engines.html)
micabeau1 05-02-2008 07:04 AM
Any Bio-fuel?
there is always talk to replace deisel, any for gas?
AndysFords 05-02-2008 09:53 AM
Ethanol, but you need special permits to make your own. You can buy a conversion, you don't need to do anything to your vehicle, just reprogram the computer to inject more fuel, you can get a plug in to do that with.
IceboxFX 05-03-2008 06:42 PM
not that ethanol is gonna save you any money.. or the planet.
Knotwild 05-03-2008 08:05 PM
Check into hydrogen generators. People are starting to put effort into researching the process just like biodiesel.
Here is one link I found:
MagDrive Fuel From H2O - HHO Generators
micabeau1 05-05-2008 04:05 PM
it seems like this hho stuff is almost too good to be true. create hydrogen from water?? Is that what this is about?
Phydeaux88 05-05-2008 05:47 PM
This is a Diesel forum after all.
Best advice sell the gasser and buy a diesel !!8D
MLCRI$I$ II 05-06-2008 10:56 AM
Toyota? SmartCar? Restore a Yugo? BUY A DIESEL AND START COOKING.}>
micabeau1 05-06-2008 07:40 PM
looks like i wandered into your realm.
tr0y 05-09-2008 12:38 AM
Make Fuel at Home With Portable DIY Refinery | Autopia from Wired.com
orng1 05-09-2008 02:18 AM
Why did nobody say propane? Oh yeah propane!
thosfsull 05-09-2008 06:30 PM
frontpage | Permaculture & Alcohol Can Be A Gas
Make your own Fuel
thosfsull 05-09-2008 06:35 PM
In Blume's Book above, he claims a Volkswagon TDI was modified to LOWER the compression some and run on alcohol. End result 22% better mileage than when it was on Diesel.
460429_freak 05-12-2008 09:48 AM
only thing i've tried is a 60/40 mix 60 gas 40 e-85 seem to work okay to no ill destruction of my motor... so at the present time gas is 3.58 e-85 2.85 ... equals about $40 bucks saved each week on 100 gallon fill up (and I burn that much) and the sam milage... but if I go over the 60/40 mix milage goes down tried this on 4 differnt vehicles. (dailey trip is 110 miles)
93 ford explorer 4.0
96 chevy astro 4.3 vortec
96 chevy p/u 5.7 vortec
00 explorer 4.0 sohc
angus 05-12-2008 04:39 PM
Methanol looks interesting. It looks like you need to drill out the jets in the carb, mess with the timing, use an engine with hardened valve seats, and run a catalytic converter (if you don't already have one) to clean up the emissions. Oh yeah, and in cold weather you'll need to start it on gasoline, or rig up a way to warm the alcohol up first. There's probably a good discussion someplace else.
