can't find a new harmonic balancer?!?
ok, I guess I need a new harmonic balancer for my 96 f-150. The problem is, no one has one. They sell them for bo*th the 5.0 and 5.8 (I have a 5.8) but they don't have the tone ring on em for the cranshaft position sensor (aka misfire sensor)
Anyone have any idea on where I can get one? I also need the pickup sensor which I was able to find, but not the timing indicator that goes over it. Ford says they can order one, but they are not sure if it what I need, but it is $240, which is a hellofa lot of coin for a stock dampner. really at a loss here, any help would be appreciated. |
rockauto.com has it for 62.79
it dosen't have the tone ring on the back of it.
it's just like all the local part stores, no tone ring and I need one |
Call the Damper Doctor at (530)246-2984 may be they can help?? they are in Redding, CA and they just rebuilt my original balancer for my 1965 289 HIPO.
Great Folks to deal with!!! |
ok I found some balancers, but I have interchange questions.
I need a f6te-ja. I found these 3 balancers, but I am not sure if they would work ENGINE TYPE : FORD 302/351 1981-UP F/N E2TE-D3A, E1TE-E3A 4 BOLT PULLEY 1 1/2" RING WIDTH 5/8" PULLEY HEIGHT STARWHEEL ON DAMPER TIMING @ 30 DEGREE COUNTER CLOCK PART # FO302-5 ENGINE TYPE: FORD 302/351 1980-UP F/N EOAE-F1A , EOAE-F3A TIMING @ 60 DEGREE COUNTER CLOCK 4 BOLT PULLET PULLEY HEIGHT: 7/8" RING WIDTH : 1 1/4" STAR TIMING WHEEL PART # FO302-6A ENGINE TYPE : FORD 302/351 81-UP F/N E1TE-C3A ECC TIMING WHEEL RING WIDTH 1 1/4" 7/8" PULLET HEIGHT 4 BOLT PULLEY TIMING 30 COUNTER CLOCK PART # FO302-6 DamperDudes.net (Americas Largest supplier of harmonic balancers) I've dropped em a message, hopefully I'll hear something back soon, but I'll probably have to wait till monday. Any info from you guys is always appreciated. |
I've talked to em and apparently they cannot help me
