Updated TSB's??
Can anyone with such info post the updated TSB list for the 2007? I would like to see what has been added.
08-4-13
Hesitation After Tip-in From A Stop/bump While Braking To A Stop Below 10 Mph (16 Km/h) - Vehicles Built Before 12/3/2007 08-4-3 Malfunction Indicator Lamp (mil) On With Diagnostic Trouble Code (dtc) - P0456 08-4-2 Cold Start Fead Hoot - Whistle Noise / Built Before 1/28/2008 08-1-9 Spark Plug Removal Instructions - 5.4l 3v 08-1-4 Water Leak - Roof Opening Panel During High Pressure Car Wash 07-26-3 A/c Compressor - Cuts Out High Ambient Temperatures/seized - Poor A/c Performance - Built Before 11/1/2007 07-25-6 Abs Light On - Vehicles Built Before 2/15/2007 07-24-8 Engine Misfire During Cruise With Or Without Dtcs (mexico Only) 07-22-4 Poor Seat Cooling Performance - Built Before 7/16/2007 07-22-3 Gap/fit - Headliner To Roof Opening Panel 07-21-6 Climate Control Seat Function Inoperative - No Communication - Dcsm - Vehicles Built Prior To 8/31/2007 07-19-8 Wind Noise - A Pillar Area - Built Before 5/7/2007 07-18-5 Battery Draw And/or Crank/no Start - Vehicles Built Before 12/6/2006 07-15-5 Poor Seat Cooling Performance 07-13-4 Wind Noise Around Front Doors - Built Before 12/6/2006 07-12-3 Rcm Fault Reporting Using Dtcs And Bit-mapped Parameter Identifiers (pids) - Service Tips 07-10-13 Rear Wiper Inoperative 07-10-6 Mil On - Dtcs P2107/p2110 - No Driveability Concern 07-10-5 Front Door Side Glass Scratched Due To Collection Of Dirt/debris In Warped Outer Window Molding 07-8-11 Harsh 1-2 And/or 2-1 Shifts, Tip-in Hesitation Or Surge, And/or Long Engagement Time 07-8-8 No Tachometer Signal, Instrument Cluster Warning Indicators On And Engine Still Runs - No Crank / No Start 07-7-4 Message Center Switches Inop-text Blank/scrambled/compass Inop/washer Light On/oat Reads High 07-6-3 6r60/75 - Dtc-mechatronic Assembly / Possible Wrench Light On 07-5-13 Discharged Batteries - Vehicles In Storage/limited Usage 07-5-8 Battery Service - Operation Of Battery Eye - Charging Service Tips 07-5-5 6r75 Transmission 2-3 And/or 4-5 Shift Flare, Possible Wrench Lamp Illuminated With Dtc P0782 And/or P0784 07-4-5 Vibration Diagnosis - Tire/wheel Runout 07-4-3 Leather-wrapped Steering Wheel - Leather Coming Loose 07-1-7 MerconŽ Atf Replaced By MerconŽ V As A Service Fluid For Some Power Steering Systems 06-25-15 Aluminum Body Panels - Corrosion - Service Tip 06-25-3 Pioneer Navigation Radio - Seek Function Inoperative - Service Tip 06-24-15 Power Folding Mirrors Fold And Unfold Un-commanded 06-23-15 Service Tips For Optional Navigation System Radio 06-21-19 Heater Core Leakage And Electrolysis (information Only) 06-21-7 Audio / Navigation Service And Ordering Procedures 06-17-8 Service Wiring Harness Replacement Guidelines - Service Tips |
Anyone have access to the TSB details? I'd like to know more about the A/C problem. There was a lot of chat about troubles in hot areas (NV & AZ)but that cooled off with the weather. I know I'll be back at the dealer when the temps rise.
07-26-3 A/c Compressor - Cuts Out High Ambient Temperatures/seized - Poor A/c Performance - Built Before 11/1/2007 |
I am also curious about the seat cooling tsb.. My seats hardly do any cooling compared to other trucks I have been in..
-R. |
I would love to see the details for
Wind Noise - A Pillar Area - Built Before 5/7/2007 07-18-5 Wind Noise Around Front Doors - Built Before 12/6/2006 07-12-3 I think those are a bit older. I had the mirrors and outer weatherstripping replaced and there still is wind rush/noise. |
i just started a job at Ford so once im used to the system they use there i can see what i can do to help out with those TSB's.
On this FTE forum website there is a link to TSBs. Who do we need to contact to ask them to put Expedition TSBs there? We are completely missing from that listing. Is that an oversight, or do the TSBs not exist for our listing and use here?
07-22-3
Gap/fit - Headliner To Roof Opening Panel Is this visible with the back windows open? http://home.pacbell.net/cclary1/Headliner.jpg |
What the heck is that a picture of???:-huh
Originally Posted by cjgeorge32
(Post 5977529)
Thats crazy....have you taken it in yet? :eek:
It's like that on all the 07/08's I believe. Not sure how they could fix it. But I will bring it up.
Mine is not like that....
No? Man, a few people said theirs were so I just assumed. I will let you know what they do.
Sorry berry...I was looking in the wrong place....my expy does it too....
