1996pwrstrk |
03-15-2008 08:59 AM |
Rep Points
This is something I think we should all think about ,some of you may not even know it's there. In the upper right corner of a post is a place to add to or remove rep. points from that person . It's easy to forget or not think about it but when someone helps you out with good info or an idea click on it and a screen will pop up. In this screen you can leave a message which the pereson you are giving points to can see be VERY CAREFUL ABOUT GIVING NEGATIVE POINTS. If you have any questions ask up I have been lax in this myself and thought I would thow it out there for discussion.
