Ford Truck Enthusiasts Forums
-   North Carolina Chapter (https://www.ford-trucks.com/forums/forum88/)
-   -   Just Joined (https://www.ford-trucks.com/forums/717063-just-joined.html)
O2bfishin 03-07-2008 02:27 PM
Just Joined
Just joined. I have a 79 F-250 SuperCab that is my weekly trash hauler, boat puller, and general all around workin, haulin friend. I admit it's a little overkill for what I use it for now, but I also have a truck camper I used to use more often, and that is why I have the F-250. It's in really decent shape. I just had it painted and some rust repaired in the bed. I am going to change the rear-end from a 4:10 to a 3:54 in the coming weeks and presently am going over the rear brakes and replacing a seeping master cylinder. It's a 460 so my mileage is pretty much as expected... about 9 mpg whether haulin, sittin still, movin, not movin, runnin, not runnin.. you get the picture. I would really like to see 10 or 11mpg if possible. I am hopin the r/e change will help that a little. It has a Holley carb so I will probably be researching the forums some to see if there is a slightly more efficient carb and/or intake setup. Not looking for miracles here just modest gains. Course you can buy a LOT of gas for what new trucks and payments cost you. I only put about 1 to 2k miles on the truck in a year. Enough for now.....
92Flareside4x4 03-10-2008 10:26 PM
Welcome from another newbie....
79 Trailer Special 03-10-2008 10:43 PM
Welcome to the group. If you come across a Edelbrock carb it should help on the gas a bit. I would average 11 MPG on mine with a 37" tire and 4.10's
biga17133 03-14-2008 02:40 PM
Welcome To The Ford Family,,,
SuperSnake 03-14-2008 03:35 PM
Run,While you can!!! Just joking hope you will like the NC Chapter.
TARHEEL57 03-18-2008 11:28 AM
How exactly do you join ?
Chad
SuperSnake 03-18-2008 11:32 AM
Chad
Go to your user cp and scroll down the left side column and you should see a link for joining.
