type of oil to use in a 6.0
What kind and weight of oil is recomended in a 2003 6.0. what do ya'll use? We run rotella 15-40 in our other diesels would it be alright to run that in the 6.0 too? Thanks Justin
type of oil to use in a 6.0 |
Since you asked... There is a boat load of them (pun intended:-X21).
Conventional Lubricants: Motorcraft Super Duty 15W-40 or 10W-30 Penzoil Long-Life 10W-30, 15W40 Shell Rotella-T 15W-40 Chevron Delo 400 15W-40, 10W-30 Mobil Delvac 1300 Super 15W-40 Valvoline/Cummins Premium Blue 15W-40 Union 76 Guardol QLT 15W-40 Union 76 T5X Heavy Duty 15W-40 Kendall Super-D 3 15W-40, 10W-30 Quaker State FCI HDX Plus 15W-40 Exxon XD-3 Extra 15W-40 Phillips 66 Super HD II 15W-40 Conoco HD Fleet Supreme 15W-40, 10W-30 Citgo Mystik Premium Fleet 15W-40 Citgo Mystik JT-8 15W-40, 15W-50, 10W-30 Castrol GTX Diesel 15W-40 Synthetics: Amsoil 15W-40 Synthetic Blend Oil Chevron Delo 400 Synthetic 0W-30 or 5W-40 Mobil 1 Turbo Diesel Truck Oil 5W-40 Synthetic Mobil Delvac 1 ESP 5W-40 Synthetic Motorcraft Super Duty 5W-40 Synthetic Valvoline Premium Blue Extreme 5W-40 Synthetic Shell Rotella T 5W-40 Schaeffer's Supreme 7000 Synthetic Blend 15W-40 Schaeffer's Supreme 9000 Synthetic 5W-40 Kendall SHP Diesel (synthetic blend) 15W-40 Petro-Canada Duron XL 15W-40 Synthetic Blend Royal Purple Synthetic 15W-40 Citgo Mystik SX-8 15W-40 Synthetic Blend Advantage Duragard Super HD 15W-40 Ford is recommending to use the following oils for the listed operating temperature: SAE 15W-40 is the preferred oil above 30 degrees, but it is acceptable for use down to 10 degrees, and is recommended for towing down to this temperature. SAE 10W-30 is the preferred weight between -10 to 30 degrees. SAE 5W-30 and 5W-40 is acceptable for use below 30 degrees, and 0W-30 is acceptable below zero. (All temperatures are in Fahrenheit) Most (not all) of the above info is from BITOG which is an excellent source of oil info:-X22 FWIW Many 6.0 owners run 5W-40 synthetic year round with great results- |
I've done UOA (used oil analysis) on my 6.0 for almost 4 years now. I've used Rotella 15w-40, Rotella 5w-40 and Mobil 1 5w-40. The Mobil gave me the best results, less shear being the most noticable quality. Downside to the Mobil- price, $22 per gallon.
No Offense---:-RTFM
I'm going Rotella Syn 5w40 on my next change. Maybe if I want to spend the extra money I'll eventually go Mobile. My dad has the same engine and we've discussed buying Mobile by the 55 gallon drum, but he does a lot of heavy towing so I think he should stick with a 15w-40. Maybe I'll still buy a drum though, 55 gallons is only 15 oil changes :)
ive been running rottela 15w-40 in the late spring threw the late fall.And run rottela 5w-40 syn from the late fall to late spring.I will be looking into staying with a syn oil threw out the year.Starting this year.iam thinking about royal purple or Lucas oil.
But rottela 15w-40 and 5w-40 syn has been good to me for almost 5 years and over 100,000 miles |
I want to find an oil and stick to it since I've heard switching back and forth is not good. So I guess I'll stick with synthetic 5w-40 year round. I don't do much towing anyway.
Delo 400, year around. I ran it in my 97 stroker to.
Hay utahtom, where are you in northern Utah? Im in Brigham City? |
Does anyone recommend the 15w-40 Mobil Million Mile Oil?
I use Mobil-1 year round
will it hurt it to run rotella 15-40 year round in it
