00 f-350 Rear Axle Code?
I am trying to figure out what gears I have in my 00 F350, its a 7.3L, 6SPD.4X4. Crewcab, Longbed, 4x4 Offroad. I looked on the label on the door pillar but theres no code there under axle? How do I figure this out? Thanks for your help. Built date is 9-99 if that helps.
Ford usually has a metal tag hangin off one of the diff cover bolts. It will have a series of numbers and letters on it something like this.. 9 3L75 that would be a 9" rear with 3.75 ratio and locking diff if theres no "L" between the numbers it has an open diff.
Unfortunately there is no tag on the diff anywhere. I am trying to find out what the ratio is. Thanks
They also stamp the code on the axle tube itself, tags can be torn off, fall off, etc. You can PM your vin # and I can find out what it had from the factory for you.
<TABLE width=740><TBODY><TR><TD>VIN:</TD><TD noWrap>1FTSW31F6YEA55613</TD><TD>Veh Line:</TD><TD noWrap>T/F7 - F250HD/350/450/550 [99-08]</TD><TD noWrap>Eng Serial No:</TD><TD>1124784F</TD></TR><TR><TD noWrap>Model Year:</TD><TD>2000</TD><TD noWrap>Market Derived:</TD><TD noWrap>F - FORD</TD><TD>Body Shell:</TD><TD noWrap>*</TD></TR><TR><TD>Veh Type:</TD><TD noWrap>T</TD><TD>Drive Code: <TD noWrap>T/E - 4 WHL L/H PART TIME DRIVE</TD><TD>Engine:</TD><TD noWrap>T/DS - NAVISTAR 7.3L OHV DI TC V8 DSL</TD></TR><TR><TD noWrap>Inv. Dealer:</TD><TD noWrap>*</TD><TD>Body Cab Style:</TD><TD noWrap>T/BC -DOUBLE CAB (CREW CAB)</TD><TD>Transmission:</TD><TD noWrap>T/VF - 6 SPD MAN TRANS Z/F M6HD-C</TD></TR><TR><TD></TD><TD></TD><TD>Version/Series:</TD><TD noWrap>T/CD - 350 SERIES</TD></TR></TBODY></TABLE>
<HR><!--ADD trace serial numbers --><TABLE width=740><TBODY><TR><TD>Trace Eng Serial No:</TD></TR><TR><TD>---------1----------2---------3--------4---------5-----------6----------7---------8</TD></TR><TR><TR><TD>NA</TD></TR></TR><TR><TD>Trace Trans Serial No:</TD></TR><TR><TR><TD>NA</TD></TR></TR></TBODY></TABLE><!-- end --> <HR><TABLE><TBODY><TR><TD colSpan=4>BUILD INFORMATION: </TD></TR><TR><TD>Region:</TD><TD>NA - ##########</TD><TD>Plant:</TD><TD>A1 - KENTUCKY TRUCK PLANT BUILD</TD></TR><TR><TD>Country:</TD><TD>USA - ##########</TD><TD>Prod Date:</TD><TD>01-SEP-1999</TD></TR></TBODY></TABLE> <HR><TABLE><TBODY><TR><TD colSpan=4>SALE INFORMATION: </TD></TR><TR><TD>Region:</TD><TD>NA - ##########</TD><TD>Selling Dealer:</TD><TD>152042 -*</TD></TR><TR><TD>Country:</TD><TD>USA - ##########</TD><TD>Selling Dlr St/Prov:</TD><TD>TX</TD></TR><TR><TD></TD><TD></TD><TD>Buyer St/Prov:</TD><TD>*</TD></TR><TR><TD></TD></TR></TBODY></TABLE><TABLE><TBODY><TR><TD>Arrival Date:</TD><TD>16-SEP-1999</TD><TD>Red Carpet Lease:</TD><TD>*</TD><TD></TD><TD></TD></TR><TR><TD>Sale Date:</TD><TD>20-SEP-1999</TD><TD>Fleet/Retail/Co. Lease:</TD><TD>R</TD><TD></TD><TD></TD></TR><TR><TD>Warranty Start Date:</TD><TD>20-SEP-1999</TD><TD>Modified Vehicle:</TD><TD>*</TD><TD></TD><TD></TD></TR><TR><TD>Orig Warranty Date:</TD><TD>20-SEP-1999</TD><TD>Reacquired Vehicle:</TD><TD>*</TD><TD>Vehicle Export Flag:</TD><TD>N</TD></TR></TBODY></TABLE> <HR> <TABLE><TBODY><TR><TD>VOC/EOC: </TD></TR><TR><TD>---------1---------2---------3---------4---------5---------6---------7---------8----------9----------</TD></TR><TR><TD> W31YEA556131723 L 3M1 23H9006 CF EH 6D1Z43 2NSQT 2KX R SM B 52B042 93 Z1 8HS 8 F</PRE></TD></TR><TR><TD> 1FTS6 1 H P 618A 9F6TX M</PRE></TD></TR></TBODY></TABLE></P><HR><TABLE><TBODY><TR><TD colSpan=4>INSTALLED OPTION INFORMATION: </TD></TR><TR><TD>Air Conditioning:</TD><TD>T/B - MANUAL AIR CONDITIONER</TD><TD>GVW Code:</TD><TD></TD></TR><TR><TD>Alternator Amp Rating:</TD><TD>8E</TD><TD>GVW Class Code:</TD><TD>S</TD></TR><TR><TD>Audio Disk:</TD><TD>* - [N/A]</TD><TD>Instrumentation:</TD><TD>* - [N/A]</TD></TR><TR><TD>Axle Ratio:</TD><TD>EGAJB - 3.73 FINAL DRIVE RATIO</TD><TD>Mirror(Driver Side):</TD><TD>AQ - DRIVER PADDLE FOLD AWAY MIRROR</TD></TR><TR><TD>Axle Type:</TD><TD>EGJAC - LIMITED SLIP REAR AXLE</TD><TD>Mirror(Psngr Side):</TD><TD>* - [N/A]</TD></TR><TR><TD>Battery Amp Rating:</TD><TD>BA</TD><TD>Paint:</TD><TD>PNYW5 - OXFORD WHITE WB C/C-W/B</TD></TR><TR><TD>Brake Code:</TD><TD>* -[N/A]</TD><TD>Power Antenna:</TD><TD>* - [N/A]</TD></TR><TR><TD>Brake Code(Service):</TD><TD>* -[N/A]</TD><TD>Radio:</TD><TD>BE - ELETR PREM STRO/CSTE/DISC/CLK</TD></TR><TR><TD>Calibration Code:</TD><TD>*</TD><TD>Sound System:</TD><TD>* -[N/A]</TD></TR> <TR><TD>Color(Accent):</TD><TD>* - [N/A]</TD><TD>Suspn Tandem Axle:</TD><TD></TD></TR><TR><TD>Color(Trim):</TD><TD>000HF - MED PARCHMENT</TD><TD>Tire Brand:</TD><TD>* - [N/A]</TD></TR><TR><TD>Delivery Type:</TD><TD>0</TD><TD>Tire Size:</TD><TD>D3JYF - LT265/75R-16E A-S BSW</TD></TR><TR><TD>Driveshaft Code:</TD><TD>*</TD><TD>Traction Control:</TD><TD>* - [N/A]</TD></TR><TR><TD>Front Seat:</TD><TD>T/S - SEATS - INDIVIDUAL 40/20/40</TD><TD>Wheel Base:</TD><TD></TD></TR><TR><TD>Fuel Type:</TD><TD>* -[N/A]</TD></TR></TBODY></TABLE> |
Thanks Rotun, You have any idea what the fuel mileage will be on this with the 3.73 axles?
If you are light on the throttle and brake you could get 20 MPG.
hey rotun do you think you could find the axle codes from my vin too, i tried this sites vin decoder but it didnt have it.
1fthx26g0jka08118 i also looked on my axles but couldnt find it. |
A 7.3L with 3.73's AND a manual trans.............hard to say as most vehicles with identicle equip. vary in mpg, but you should see at least 17-20. I get 17-18 on my '03 7.3L with auto trans. with a full lumber rack installed and I'm not easy on the pedal. |
1fthx26g0jka08118 i also looked on my axles but couldnt find it. Well, I tried, can't go any farther back then a build date of July 2000. Check all around the rear axle tubes, there are codes stamped, then you can decipher gears through the codes. |
