Ford F53 V10 motorhome - Where is OBD?
Can't seem to locate the Data-port.
Any help will be appreciated. Also, do you have a thread for Ford motorhomes? |
If it is not under the dash on drivers side I am not sure.
It should be under the dash near the steering wheel location. You may want to try logging onto www.rv.net and go to the Class A motorhome section and try posting this same question. A lot of great information located on that site for all RVing subjects.
Any help will be appreciated. Also, do you have a thread for Ford motorhomes? Mine was on steering column, under the plastic shrouds, next to my right knee. As mentioned above, search F53's on RV.net for more info. |
I haven't gone out and looked for mine yet but, my understanding is that it is within reach of the driver's seat, to the right of the steering wheel, under the dash.
There is a Ford Motorhome Chassis Forum on iRV2.com http://irv2.infopop.cc/eve/forums/a/frm/f/5931040402 It's all Ford motorhome chassis but, there's a lot of F53 discussion. Probably more than the others combined. |
Hi There I have A 1999 holiday rambler Vacationner . I just found mine it is under the steering cover on the right side it is mounted on the bracket that holds the steering wheel when it was a chasse .its hard to get to the screws to remove them .I moved mine on the face of the dash just under the dash, Hope this helps Bob
