is the truck to big
i have built a 1979 ford f150 4x4 truck. it has a 10in suspenion lift and a 5 in body lift. it came with a 351modified400 and a divorce transfer case. I bought all rough country suspenion shocks and springs and other stuff. I put a set of 42 in supper swampers on it. it is big now but what is ya'lls opion on a set of 54in tires.
Terry |
NO!!!!!!!!!!!!
It Can't be too big. Any Pictures. Bob |
Let's see it!! put the 54s on
I cant see it going very far with 54s
Hey I thanks for the replies I will post pics when I figure out how.
What kind of gears are you running? I'd look into some deep gears if you're going that high on tires. Your Trans will thank you man.
Ry |
I have contacted rough country and told them all I was doing to the truck and they sent me a set of 6:55 gears I thinkall I know is they where a little over 400 dollars. Still working on truck it has 48 in supper swammper iroks still working on 13 inch lift and 5 inch body. to get the 54 inch tires on it
Sounds sweet man, I can't wait to see pics!!
i dearly hope that you or someone has swapped out those 1/2 ton axles in lieu of either cromo'd/built D60/10.25 or a set of rockies! just hitting the brakes too hard with 54's will break that D44/Ford 9!
also, not sure i have ever heard of 6.55 gears?!?! you're truck is going to fall off the frame with a 5" body lift! that is just stupid! bring that down to a 2" body lift and add some suspension lift if needed (which i doubt). otherwise, stay outta my part of town! i'm thinking BS until i see some pics, nothing personal, just seems theres a lot of people running 15" of lift and 54" michies! -cutts- |
Take a READ, and see why thats a BAD IDEA... https://www.ford-trucks.com/forums/7...he-how-to.html
I would say that the max for a body lift is 3 inches, but thats the biggest they are sold right?
Originally Posted by cletus_the_red
(Post 6004959)
-cutts- |
No pics in a month and a half since to OP.. I call BS. He's probably madly fabbing away with hockey pucks for the body lift, and light bars from a Ted Nugent concet for a subframe, just to make it look like he described.
In the mean time.... I have an 07 PSD, where can I get some 54's so that my quad front shocks dont look out of place. And how can I cut down my brake calipers so I can fit 15 inch wheels on.:-lamesign |
i found it
dude you guys i found his truck check it out!
https://www.ford-trucks.com/user_gal...id=184347&.jpg :-X18 but i dont think he put the 54s on it yet hahaha the things people do with their money... |
in..... thanks for the chance.
