'92 Ford explorer burning oil?
I just bought a '92 ford explorer and gave it a tune up. I only put about 400 miles on it and I am putting the second qt. of oil in it. I haven't seen any leaks at all and it isn't puffing out blue smoke. I heard I should Check the spark plug from cylinder #5 for crusty deposits. Apparently the lower intake manifold gasket has a habit of leaking oil into that cylinder. Any body have any other ideas before I tear into this thing?
Check the plugs and do a compression test, Post results
I heard I should Check the spark plug from cylinder #5 for crusty deposits. Apparently the lower intake manifold gasket has a habit of leaking oil into that cylinder. |
I already did a compression test and everything was fine
I did torque down the intake it was a little loose but not too bad i'll see how that works.
