2008 Super Duty named Four Wheeler Pickup Truck of the Year
Not sure if you guys have gotten the new issue- but it won FW TOTY, and yes it beat out the Tundra.
The SD just BARELY squeaked out a win over the Hummer H2 SUT (I'm talking like .4 points margin) |
Is there anything online about this?
Originally Posted by obxredneck
I googled and googled but I could not find nothing about it. Somebody will probably come along and find it in 2 seconds though.
Same here that is why I asked....:) |
The Super Duty makes a very good candidate for off road upgrades. Gotta love solid axles all the way around. If I were in the market for a 3/4 ton it would more than likely be the new Super Duty with the Powerstroke and a 6 speed handshaker.
I may drive a Tundra, but I don't hate Ford Trucks. I just hate the 5.4L Triton V8, and the antique transmission hooked up to it. |
Nice work there V10_Cougar....:-X22
I may drive a Tundra, but I don't hate Ford Trucks. I just hate the 5.4L Triton V8, and the antique transmission hooked up to it. Are you calling there new Torc-Shift 5 speed Transmission Antique |
I also wouldn't cry (and neither would Ford Superduty buyers) if the Torqueshift gained another gear, or maybe even two more gears. Think of how cool a heavy duty seven speed hooked up to a 6.4L diesel would be. It could have both a double overdrive and a really really low first gear. Now that would be some flexibility. |
Originally Posted by V10_Cougar
And here you go:
http://blogs.fourwheeler.com/6226116/miscellaneous/oty-awards-on-display/index.html |
Not yet. I am calling the atrocious 4 speed auto used in the F150 an antique. Not that more gears would help that anemic lump that is the 5.4L Triton V8.
I also wouldn't cry (and neither would Ford Superduty buyers) if the Torqueshift gained another gear, or maybe even two more gears. Think of how cool a heavy duty seven speed hooked up to a 6.4L diesel would be. It could have both a double overdrive and a really really low first gear. Now that would be some flexibility. Torqshift is a great transmission...They have not had the issues with them like the older 4 speed auto's....By the way the 5.4 is a better motor after "03" I like the one in my "04" hated the one in my old "99" |
I like the one in my "04" hated the one in my old "99" http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=251 http://www.factorytechtransmissions.com/index.asp?PageAction=VIEWCATS&Category=5 |
Both of my 4 speeds have been rock solid also. Except for the converter "shudder". ( easily fixed by a fluid change )
I would be happier if the 4 speed in the Expy had 1 or 2 more gears..... |
One thing. I like about the Torqshift is that when you shut off the tow mode on it. And then tap your foot on the brake it down shifts and saves your brakes
