your truck info under your message
when you read a thread, under what you read has a discription of the persons vehical or a saying they put in. ever time they respond to something it shows up under what they type. how do i go about setting it up?
Go to User control panel/user CP. Then click on edit signature.
ok i'll try that. thanx
Let me know if you need more help.:-wink
got it done. worked out perfect. check it out. THANX!
Your welcome.
Good job,,,looks good.:-X22 |
Phil, I need help. I was going to ask the same question until I came across this post. I went to CP. I have no listing for edit signature. It shows a lot of other edits, but not that one.
Best, CB |
Best, CB When you get 25,it may take 24hours after that, before you get it in your CP.But it will show up. |
OK,I've tried to add a quote from one of the members to my sig and it isn't working.The user cp panel doesn't show how to do that.Can you tell me what I'm doing wrong?
Thanks. |
