Ford Truck Enthusiasts Forums
-   1987 - 1996 F150 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum28/)
-   -   1987 to 1996 Tech info (http://www.ford-trucks.com/forums/691447-1987-to-1996-tech-info.html)
rbloodhound 01-05-2008 11:34 AM
This will be a list of links to FAQ's and info for our trucks. Please read only and do not post. If you want to add info please put it in the stick thread suggestion thread. We will try to get this thread stuck.
ELECTRICAL
Spark plug wire routing
intermittent wiper(no cost fix)
Checking OBDI codes (EEC-IV)
TRANSMISSION
Torque Converter Clutch Lockup Switch
BRAKES
heres how to do a brakeline
http://www.ford-trucks.com/forums/6...-how-tough.html
Front disc brake replacement (including auto hub dissembly)
electrical fan interchange! not sure if this is the right one to put up but its has pics.
http://www.ford-trucks.com/forums/6...ectro-fied.html
GENERAL MECHANICAL INFO
leaf spring shackles how to
also spring shackles
92-96 Coil Spring Specs
fuel tank sizes
on tank filling the other tank
clock spring replacement pictures
thank you ladyfire 3374
airbag code32 and clockspring replacement
BODY PARTS
interchangable doors
http://www.ford-trucks.com/forums/673298-door-swap.html
tailgate interchange
RADIO RELATED
87-91 radio removal
Tips for installing Sirius satellite radio
GENERAL INFO
<TABLE><TBODY><TR><TD vAlign=top width="100%">gear ratio & tire sizes:
http://4lo.com/calc/geartable.htm </TD></TR></TBODY></TABLE>
a quicker search for forums (post #11)
Thank you federic!
<TABLE><TBODY><TR><TD vAlign=top width="100%">I want to thank everyone who contributed especially ameritaz3038.
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Manual Injector Cleaning - The How To Thread
http://www.ford-trucks.com/forums/10...to-thread.html
3G Alternator Swap: Should I think about doing one?
http://www.ford-trucks.com/forums/11...doing-one.html
Ford Steering Box Rebuild
http://www.ford-trucks.com/forums/10...x-rebuild.html
Ford Front End Rebuild and auto hubs replacement
http://www.ford-trucks.com/forums/11...l#post11243835
Ford Rear Drum Brakes
http://www.ford-trucks.com/forums/11...l#post11743946
Adding Cruise Control
http://www.ford-trucks.com/forums/11...e-control.html
