Looking for break booster seal, 1964 FORD F350
I am looking for a seal that goes inside the break booster for a 1964 FORD F350.
I am not sure that it is the original booster but it may be. There is a shaft that slides snugly through the center of this ring seal. The inside diameter is 1 3/16 inches. The outside diameter is 1 7/8 inches.on the smooth side. The outside diameter is 2 inches.on the beveled side. Here is a link to a picture of my seal. http://www.taftpcservices.com/HOLD/1...OSTER-SEAL.jpg Please let me know if you have one or where I can get it. Thank you, Arthur |
Welcome to FTE, Arthur.
I'd suggest posting this in the 1961-1966 F100 & larger trucks forum. You will have a lot better chance of someone seeing it that can help you out. |
Originally Posted by ARTIZAN
I am looking for a seal that goes inside the break booster for a 1964 FORD F350. I am not sure that it is the original booster but it may be. There is a shaft that slides snugly through the center of this ring seal.
The inside diameter is 1 3/16 inches. The outside diameter is 1 7/8 inches.on the smooth side. The outside diameter is 2 inches.on the beveled side. Here is a link to a picture of my seal. http://www.taftpcservices.com/HOLD/1964-FORD-F350-BOOSTER-SEAL.jpg Please let me know if you have one or where I can get it. Thank you, Arthur I sent you an email inre to the booster. Please start a new thread on this topic in the 1961/66 forum, so others here may take advantage of what's found. :-X25 |
I've had good luck finding parts in the National Parts Depot catalog (on line).
