How do you remove the ashtray 2002 Ford F350?
This likely seems like a simple issue, but is there a trick to removing the combination ashtray / cupholder on a 2002 Superduty? I took the two bolts out but couldn't pull it out, and I'm wondering if there's a trick to removing it? Maybe some clip I can't see?
Mine's gotten pretty dirty over the years, and I'd like to remove it for a thorough cleaning. Thanks. |
I think if you remove the trash hook, there are 2 more bolts you can access by reaching through the space created.
Thanks, I'll give that a try.
Check out my gallery here, it has instructions on how to swap out the cupholder. Instead of removing the ashtray you'll remove the trash hook like Riggz mentioned.
https://www.ford-trucks.com/user_gal...&albumid=27106 |
