Torque converter clutch lockup switch
I know this has been covered before, and I bookmarked the thread, but I've got another question. I'd like to install a torque converter clutch lockup switch that will allow me to lock the converter at any speed/RPM but I'm a bit confused as to how the electrical circuit works. The torque converter is UNLOCKED when it has +12v to it and LOCKED when the voltage is removed? Or vice versa? Thanks.
The clutch is on when grouned, off when not grounded. http://i54.photobucket.com/albums/g9.../1995E4ODF.gif / |
what is the point of this mod
So then installing a switch inline on that wire would only allow me to UNLOCK the converter when it has been locked already be the ECU, by breaking the ground. No? If I wanted to lock the converter on command then I'd need a three way switch with the center prong running to ground, no? But then I wouldn't be able to restore the originial circuit...
To UNLOCK the converter you would break the connection between the ECU and the transmission. This site has a good diagram with LEDs for ya.
http://www.forgotton.net/mods/tclock/index.htm |
https://i54.photobucket.com/albums/g.../ModSwitch.gif / |
Ahhh yes it makes sense now!! You guys are awesome. Chris I gave you rep points but Bill I can't give you more until I "spread it around". Thanks you guys.
What are the benefits of manually locking/unlocking the torque converter? I have no clue about how this works. When its locked what does it do? Sorry to thread jack
I know Bill it kinda sucks... I know I'm not nearly as knowledgable as you but when I actually DO know something, I don't get the rep for it... :p
Playa_fl, click on Chris's link above and it explains the benefits of the TC lockup switch at the bottom of the page. |
If you have the Mod it can be used for towing above about 25 MPH and engine braking. This can also keep the oil cooler in the transmission. |
