Adjustable caster/camber cam kit install Question.
I have a quick question on installation of the upper control arm cam adjuster bolt kit.
99 F150 2WD Is there any particular way to initially set the eccentric bolt/washer combo when installing a kit along with replacement upper control arms? Should it initially be set up/down/sideways (left/right). I will be getting an alignment, but it may be a few days off and I need to be able to dirve the vehicle in the mean time, so some general tips would be appreciated. Thanks Dialtone |
I am by far no expert here, but common sense says straight up. Good luck! :-wink
before you loosen the bolts on the a-frame, mark the location with a black marker or center punch- both bolts. put them back in the same location. if you want to install the cam kit, o.k., or just take it with you and give to the allignment guys.... i have done several upper arms and all i do is center punch the frame around the washer on the bolt head, then put them back in that same spot.
When you take the bolt and nut out, you'll see where they were installed(at least in northern mn, you can see the rust around the bolt). Put the washer and bolt combo in so that they closely line up. I guess I never really pay alot of attention, because when I'm putting them in, it's already on the alignment rack and I'll be adjusting them within 5 minutes anyways. But you may even be able to see where the arm itself was lined up on the inside of the frame and just turn the bolt after it's in and line the 2 marks up....you'll see what i'm talking about after you have the bolt/nut out....
Well, Just finished up replacing both sides, and the job was easy enough. About 30 minites per side (once I located the proper size wrenches/ sockets to use)
Curious though that the factory had installed a rectangular "locator" plate on the nut side of the original setup. This plate basically "fixed" the bolt position in the slotted frame mounts, so I just reinstalled them. Will take the adjusters to the shop when I get it aligned. But I really do not see what the big deal is. Looks like one could remove the locator plates and slip the bolts along the slots to get the proper alignment without the fancy cam bolt setup. Looks like a waste of $45.00 to me, but possibly I am not seeing the big picture here. Thanks for the replies. Dialtone |
i have had 50 guys tell me you cant align it without the cams. I have nvere ever seen one of the cam kits. do it all the time like we talked above. just put it back where it came from. you rright, you dont need the cams.
I've aligned the without the cam kits. SUCKS!! You have to fight with the upper control arm and hold it in place while your tighten the bolts. It's not worth my time(or losing my time) to fight the alignment without the kit. It's 100 times easier to align it with the cams.
and the spacer that is factory installed sets the caster camber to a predetermined measurement, so they don't have to align it before shipping. |
ive got a 99f150 4x4
was looking into replacing stock right upper ctl arm/ball joint myself and had no idea about this adjustment kit...is it safe to assume that it would be pointless to install the new parts (including this kit)only on one side or does it make the alignment a nightmare and a half for the shop with one moog aftermarket adjustable and one stock ford part working with on a limited budget but if i have to replace both sides with the adj kit then it will be done that way |
