Door Swap
Hi,
My 95 F-150 has messed up doors on it & my buddy has doors off a 1988. I was wondering if they will interchange or if at least the door glass (not the wind wings). It looks like all the mounting points are the same, but I don't want to tear stuff apart if it is not going to work. I would appreciate any advice. |
the doors are interchangable. im currently putting a 95 door on my 89 and it fits like a glove
See my gallery... my '90 has '92 doors on it, the opposite of what you are planning. I used the window glass, power actuators, and interior door skin from my '90 on the '92 doors.. all fit fine.
Ok thanks a million guys, but will the door panels off the 95 fit on the 88 doors? Is any serious mods required to do this?
My 90 F350 CCD drivers door is sagging so I have to lift it when I close it. It's the Lariat Version with power locks and widows. Any suggestions on fixing the hinge or swapping the door?
Is there some sort of adjustment on the door itself? The door on my 96 was replaced before I bought it. But it looks like it doesn't fit quite right, not to mention that when closed sitting inside the truck I can look back and see daylight through the crease and hear/feel air blowing through it as I'm going down the road (weatherstrip is 100% intact on door), when closed looking at it from outside, it doesn't look like it's fits quite right. while the passenger side door looks perfectly fine. Second.. I changed my lock cylinder (new key) passenger side door took another key and apparently nobody has the spare key to the new drivers door, it possible to get the doors keyed to the new key I have for the ignition?
I am looking for some used manual doors with mirrors or without (decent shape) and fenders for my 89. What is a good price for them? I just would like to know where to start.
Thanks |
CKDC - I'd replace the hinges or repin them. All four doors on my crewcab started sagging after a while (the drivers door being the worst as it's used most often). Simple to do - hammer out the old pin, install new bushines and hammer in the new pin and it's done. Bolt door back onto hinges or bolt door and hinges back onto cab, depending how you took it apart.
Dehamma - prices for used parts vary wildly based on condition, location, the yard itself, the yard owners mood, etc. One yard by me in NJ for example wants $75 a door, with glass and anything attached to the door. That's not unreasonable if the glass is in good shape, the window/latch mechanisms work, and the mirror on the outside is intact. If not, find another door (or several) with good bits and combine them to make a door worth $75 :) A yard out in PA I go to once in a blue moon wants $35 for a complete door. So it varies. |
I have a 1987 F250 with electric windows and locks. What year doors will fit and does anybody the panel that goes below the armrest and controls? The interior is tan and it is for the passenger side.
Rather than post up a new thread, I think it belongs in this:
What about internal parts of the doors, specifically: -Latching mechanisms -Power lock actuators -Key Cylinders -Window regulators (And variances between power and manual versions) Will these items transfer between any year of 1987-1996? |
Originally Posted by Pele
(Post 6817951)
I would like to know if a 92 f150 front cap will fit on a 91 f150
Originally Posted by mlford
(Post 7452426)
