Trans and Engine Oil Temp Gauges
Has anyone installed any of these? Where did you find space to put the gauges?
Thanks, Rich |
I would like to see a nice setup for the Trans myself. I think it would be the most useful of any guage.
I've asked the question in the fourm already and posted a response to your engine oil cooler post. The data is in the ECM, but you must have a compatible code reader to display the extended data. For Expedition I found a couple of options, but haven't tried any. I wanted to use the Edge Evoultion programmer & gauge, but it does not work for the 2007 Expedition (5.4 F-150 ONLY).
You might want to checkout: www.scangauge.com www.dashhawk.com http://www.aeroforcetech.com/Fordtech.html |
[QUOTE=07EXPYEL]I've asked the question in the fourm already and posted a response to your engine oil cooler post. The data is in the ECM, but you must have a compatible code reader to display the extended data. For Expedition I found a couple of options, but haven't tried any. I wanted to use the Edge Evoultion programmer & gauge, but it does not work for the 2007 Expedition (5.4 F-150 ONLY).
You might want to checkout: www.scangauge.com www.dashhawk.com http://www.aeroforcetech.com/Fordtech.html[/QUOTE] Great list! Looks like only the DashHawk will read both trans oil temp and engine oil temp on Fords. Looks like a great tool for $299. To bad its not discounted somewhere yet. Thanks, Rich |
