Ford Truck Enthusiasts Forums
-   401, 477, & 534 SD Engines (http://www.ford-trucks.com/forums/forum137/)
-   -   Is there a Parts Warehouse for 534 V8 engines? (http://www.ford-trucks.com/forums/641028-is-there-a-parts-warehouse-for-534-v8-engines.html)
comstock 08-10-2007 02:35 PM
Less than 2 weeks to go before a big emergency vechicle show and meet and my 1971 C900 Ford/Howe pumper just lost its water pump on the 534cid engine. Not to worry right? Wrong!
Napa Auto Parts tells me 2-3 weeks for one from the manufacturer. Are they kidding? I cannot keep pulling over and lifting the cab to ad 10 gallons of water and will miss the meet otherwise without a new water pump.
I know the 534 V8 engines are obsolete but this is scary to drive this Fire Truck far from home if it will need to sit on the side of the road for 3 weeks waiting on a part.
Does anyone have a line on new and/or rebuilt engine parts in-stock (specifically a water pump!) for the original Super Duty engines?
dugyver 12-24-2007 10:02 AM
last time this happened to me, I was able to buy the "wrong" water pump( right housing--wrong fan hub) Pressed off the old hub and pressed it onto the new pump. It's still in operation. Country boys can survive!
q240z 01-06-2008 06:51 AM
Check the classifieds here. I just posted two 534 twin turbo engines for sale cheap.
glennbin 04-08-2008 11:40 AM
I've got a couple of super duty 534's for parts. One has vary low hours on it runs but has a cracked block. The other was pulled from my boat was siezed when I purchased it.
will sell or trade both engines for token fee . some new gaskits included
bobbbjones 01-13-2011 03:00 PM
what did you use
Quote:
Hi what pump did you use? I have the same problem, I need a water pump, but our napa has nothing and is not intrested in helping look for one. I am always looking for a good parts supply if some one knows of any
thank you
Michael Leonard
bobbbjones@yahoo.com
401477534 05-01-2011 02:56 PM
i wish i had more money, i want one of the 534s.
jowil 4850 12-11-2012 06:55 PM
Quote:
i have a L-900 72 model road tractor looking for engine/engines. What were the application for the ones you have, also the condition and price? My number is 434-660-1682. thanks W.C.jwhauling@aol.com
Beechkid 12-13-2012 03:07 PM
Water pumps are really simple & any local machine shop should have (or access to) the seals and be able to press them in. Another potental option:
Airtex Products
Fuel Pumps > Fuel Delivery System > Electric Fuel Pump
Airtex Products- Tech Support
407 W. Main St. Fairfield, Il 62837
800-424-7839
John Pestana 01-22-2013 09:52 AM
Looking for original oil filter housing or adapter to convert to a spin on type filter. 1977 534 Ford running a APU for a Ski Resort. Call me at 775-721-3937
crossy 02-03-2013 01:31 PM
just curious fellas- i remember seeing one of these sideways??? years ago in the back of a bus/Rv, what a rumble it had. What carbs were used on them , a bigger holley? and I'm guessing LOW single digit MPG's . lol, thanx , crossy
johns294 01-15-2014 10:26 AM
May be a little off topic, but where does everyone get parts for these trucks?
Napa has been zero help at all.
I was able to find a set of plugs for my 477 on e bay, but as far as anything else goes, no luck anywhere. I called a few independent parts suppliers that did not seem interested in helping.
Would anyone know of a reference that could show what ford car parts are compatible with these engines?
