Warranty and Biodiesel
So I'm interested to know if running Biodiesel effects your manufacturers warranty. If you can run it, how much can you run, what types and does it effect the coverage of the warranty in anyway?
I sure would like to start running Bio in the truck. I like the idea on so many levels I'm not sure why there isn't a station around me thats already doing it with as many diesels are on the road. |
If they can prove you are running over B5 a stealership might deny warrenty service.
I think they would have problems proving what blend you were running if the tank was full of B5 or less. Additionally, if they deny warrenty service because you ran BioDiesel they will have to prove that the problem was caused by running BD; however, they will probably make you make them prove it. |
Research online for the court case involving an 08 Superduty and running b100. I think it was on a competative diesel site. The outcome was a ruling that a third party company was not liable for a compatable and direct replacement fuel. Ford paid for the cab removal and found that the injector failure blew the engine not the fuel. I paraphrased it.
Here is a list of all OEM warranty links about biodiesel use.
http://www.biodiesel.org/resources/f...arranties.shtm |
Manufacturers will look for any way possible to wiggle out of a warrenty claim.
I can't tell you how many Ford "Mechanics" have said to me that "BioDiesel doesn't have good enough lubricating properties and that will result in early engine failure". Evidently that is the companies talking point on the subject. They also claim that BD is corrosive so it will destroy injectors and pumps. I really don't think they have done their home work on Biodiesel they see it as an unknown factor and just throw up scary objections |
What Fairbanks Morse said about B100
quote from Fairbanks Morse.....
Beloit, Wisconsin, February 1, 2007 – Fairbanks Morse Engine, an EnPro Industries company, announced today the approval to utilize up to B100 (100% bio-diesel) in its Opposed Piston (OP) Model 38D 8 1/8 diesel and dual fuel engines for continuous operations. “Our extensive tests have demonstrated that utilizing B100 fuels that comply with the ASTM D6751 testing and specification had little impact on fuel consumption and power ratings, and had positive impacts on emissions by substantially lowering particulate matter (PM) and CO values”, said Joe Eves, engineering manager – OP and FM/ALCO engines http://www.biodiesel.org/pdf_files/O...0biodiesel.pdf |
