Anyone going to Neeses this weekend
Im not sure if anyone knew but Neeses is having a mud bog this Sat at 6. I wont be able to bring out the 79 F250 because Im still trying to get the D60 front together but it is a good time none the less. Let me know if you are interested in directions or are planning to go.
Sorry,
Between changing the brakes (all fours) and some baseline testing and "work" I kinda got backed up... |
You missed one He77 of a time. The pits were as bad as Ive ever seen. Only two made it through both were little pos rice burner "sa-zuki" One pretty tough looking 80s model ford on about 3 ft of suspension lift, rockwells, 460+++ with tractor stacks and tractor tires went about 75 feet. One of the big boys from the drag style mud run was there. He normally runs in the low to mid 3 sec/200ft. This time he went about 10 ft. He shot the nitrous straight off the line and sat the whole truck on the frame in less than a second. Pretty good times! There will be more SC members need to get together and meet up.
