Biodiesel Conversion
Does any body know what I would need or could lead me in a direction to start? I want to look at converting my 02 X. Thanks.
Properly produced Biodiesel should require no modifications. WVO and SVO DO. You would have better luck posting in the 'Bio' forum.
Take Care |
Speaking from experience....I gave it a shot for 10,000 miles in my Kenworth. Fuel mileage decreased 6 %. Short of making someone FEEL better about the environment,its not what it was cracked up to be. Anyway,noone would use it if it wasn't so heavily subsidized by the government.
Nothing for Biodiesel. If you want to run WVO you need to install a heated fuel tank system.
differences are B20 is 20% biodiesel and 80% petro diesel and B99 is 99% bio and maybe 1% petrol diesel. Better is questionable, depends type of answer. the B20 will of coarse give you the benefits of running bio in added lubrication and will clean your fuel system and should improve your fuel economy. B99 might hurt your economy slightly (I don't see it with mine but many say it does) but had the benefit that darn little of your money is going to the middle east.
you will want to keep a new fuel filter with you because it will clean out the fuel system and the filter better catch it but that will plug it if your system is really dirty. but once you have gotten it cleaned up then the filter changes will go back to normal
As to the economy I get around 16-17mpg on #2 diesel get 17-18on approx B25 and around 16-17 running B100 so you can see it really isn't changing my economy much. |
Yep. All Bio goes straight into and unmodified vehicle.
Bio is modified outside of the tank and Veggie or WVO is inside. |
Moved to ...here....enjoy~
If you want to find out more about making and using biodiesel you should go here first: http://www.biodieselcommunity.org And look at past threads on this forum, there are lots of us here sharing info on making bio. |
Anything we can do to reduce the flow of cash to the terrorist supporting middle east regimes is beneficial. Anything we can do to reduce our dependence on foriegn sources of a vital resource is beneficial. Anything we can do to put folks to work is beneficial. In the short term it may cost more to operate a fleet of vehicles on BD but long term we (the nation) win and each individual benefits. |
