2000 F250 Fuse Box ID
I just bought a 2000 F250 Super Duty,7.3, Supercab, Longbed, Auto, 2WD and didn't get an owners manual with it. The interior lights are stuck on and I'd like to pull the fuse to keep the batteries from going dead while I fugure out what's wrong. Does anyone know which fuse it is? Also where could I come up with a decent shop manual for this thing?
Thanks, Lewis |
#14 under the dash. It should be a 10A. Your problem is probably the switch. It is located in the door latch mechanism. Spray a liberal amount of WD-40 into the latch and open and close several times. This is a problem with many SD owners and this little trick usually does the trick.
Thanks Silver. It looks like that is the problem, I worked both switches manually without lube and the light went out. It looks like there is some sort of time delay on the circuit but without a wiring diagram it's guess work. I'm in the process of rounding up manuals any suggestions?
