How To Control TCC Lock Up
I own a 1991 F-250 with the fuel efficent 460. I am getting the truck repainted at maaco $4000. I will be linexing the bed and hand brushing the frame. I love the truck except for the early torque convertor lockup in second gear. Is there any way I can manually control the TCC lockup with a switch?
Yes you can, I have a box that will even change gears.
I take it you have an E4OD so you would cut the circuit #480, a Pink wire with a Yellow stripe. Tape back the end going to the PCM. Take the end going to the Transmission and run it to a switch and the other terminal of the switch needs to go to a good ground. With switch off the clutch is off and when the switch is on the clutch is on. The above decryption was for a 1992, yours should be the same. |
He could also put the switch inline to produce:
OFF- Clutch is off ON- Clutch operates normally |
or use a 3 position switch and have on off and auto.
Were do I find this Pink wire with a yellow tracer at? I will probably just have a switch inline to make it easy. Is there any concern in leaving the torque convertor Disengaged, are there any guidelines? I think I will install a Temp gauge in the outlet cooler line to get the hotest fluid temp out of the TQ.
https://i54.photobucket.com/albums/g...DSolenoids.gif |
That sounds like nice performance trick. I guess I need to buy a manual to find these wires. Can you do all the wiring under the hood ? I have a 93, will it be the same ?
It main use is to turn off the clutch while troubleshooting shudder in the Transmission. |
Cool Thanks for the reply. I wonder were the Transmission tempature sensor is located at, and if it would be possible to tap into it for a temp gauge?
Transmission Fluid Temperature (TFT) Sensor 7H141: The transmission fluid temperature (TFT) sensor is located on the main control valve body (7A100) in the transmission sump. It is a temperature sensitive device called a thermistor. It sends a voltage signal to the powertrain control module. The voltage signal varies with transmission fluid temperature. The powertrain control module uses this voltage signal to determine whether a cold start shift schedule is necessary. The shift schedule is compensated when the transmission fluid temperature is cold. The powertrain control module also inhibits torque converter clutch operation at low transmission fluid temperatures and corrects EPC pressures for temperature. The Transmission Fluid Temperature (TFT) sensor is a thermistor that changes resistance in response to temperature. The TFT sensor resistance decreases as the surrounding fluid temperature increases. The resistance variation is converted into a voltage signal and sent to the PCM to give an indication of the transmission fluid temperature. Note: Voltage values are calculated for VREF = 5.0 volts: These values may vary 15 percent due to sensor and VREF variations. Transmission fluid temperature must be minimum of 10°C (50°F) before taking transmission fluid temperature sensor resistance measurements. https://i54.photobucket.com/albums/g.../TFTSensor.gif https://i54.photobucket.com/albums/g...ission/TFT.gif Good Luck |
Will having the c103 coming from trans grounded for a long time hurt it ?
If you mean circuit #480 the engine will die when you come to a stop. It would be like trying to drive a standard (stick) shift without ever pushing in on the clutch. |
Sorry, I was confused. I thought I was reading it would keep the Tourqe Converter from locking up. Thats what I would want it to do till atleast 55 mph intead of 35 mph.
