Air ride and Easy Entry
I am curious, the ford website says air ride suspension will lower your car 1 inch in park and raise it 1 inch in 4wd. Can you actually see this happen if the door is open and you are looking, or feel it happen? Because I see and feel nothing..i have even measured and nothing...
Easy entry, this means the seat should slide back when you put it in park right? Because I moved my seat most of the way forward and put it in park and nothing... YES both of the options are selected in the menu. |
I doesn't work until you pull the key out or when you put it back in.
Bob |
Bob |
The seat. It works with the key for Easy Entry if you enabled it.
