Clutch pedal bushing replacement
1995 F-250 2WD Diesel
The clutch won't release all the way so I checked the pedal bushings and there's quite a bit of movement on both sides. Does anybody have: - tips on replacing these? - online source or is it dealer only? TIA Timo |
I had a '92 F250 2WD with the 7.3L. I actually had to replace the entire clutch pedal assembly, brackets and all. If I remember correctly it wasn't too hard to replace. I replaced just the bushings once and they wore out quickly again. It seems Ford modified the brackets to increase the surface area of the bushing support. Orginally the bushings were only supported by the thickness of the stamped bracket. Later they added some material onto the stamping to increase the support area for the bushing, after that I had zero problems.
Where did you get the assembly? Maybe I could check a bone yard...
I bought mine at the Dealership! You should check to make sure yours doesn't have the modified brackets already installed. Then it would be just a simple bushing replacement. I believe the bushings are a dealer only item too. If you can take some photo's of the braket assy. under the dash, I might be able to tell you if you have the modified brackets.
Timo
I kind of had the same problem on my 92 F150 4.9L Clutch. I heard a loud pop and the clutch wouldn't release all the way. Well I went to the Ford Dealer and got new bushings and replace them. Well after I replace them it still didn't fully release. The clutch worked just find but wouldn't release all the way. Maybe about a 1/2-3/4" Short of all the way out. Well I got to looking around and found that the release spring was lying under the park brake bracket. The tang that held the spring in place broke off and dropped down. I could replace the entire clutch pedal assy, but I opted to just add a spring from the Help Section in Autozone. About $5.00 dollars for a pack of misc springs, I bent one to fint and it works as good as new. I hope this helps. Kevin |
Originally Posted by timo944
I can see very clearly that it does NOT have modified brackets - it's the first thing I noticed when I looked at it. The only bearing surface, as you say, is the thickness of the metal. I'm thinking I can go find a later model truck in a scrap yard and solve the problem once, or maybe i can modify the bracket with a little welding.
