Ford Truck Enthusiasts Forums
-   1967 - 1972 F-100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum39/)
-   -   pics of lowered 67-72 ford trucks? (https://www.ford-trucks.com/forums/600873-pics-of-lowered-67-72-ford-trucks.html)
ultraranger 01-07-2015 07:38 PM
The '03-2011 Crown Vic swap does have a number of advantages over the drop beams.
You can use lowering springs with the CV setup and the drop can be made on the CV suspension without inducing camber, unlike the drop beams that are much more limited in the amount of drop that's possible before camber problems happen.
There's also an adjustable coil over for the CV from Nakke (it's expensive but is a nice setup).
The CV comes with larger 12" disc brake rotors and twin piston calipers. The CV can be swapped to even larger 13" Cobra front brakes from the '94-'04 Cobra Mustangs with twin piston aluminum PBR calipers.
The CV comes stock with a beefy front sway bar.
The CV also comes stock with a power rack and pinion steering unit. The CV front suspension can usually be purchased for around $250-$350.00 dollars.
Drop beams and shackles alone will run you over $600 dollars. This doesn't include a power steering gear box or the addition of a sway bar. Adding these last two items to the drop beams will easily add another $250.00 dollars, or more, to the cost.
The 5-on-4.5" lug pattern of the CV also opens up a vast array of wheel possibilities. Number of wheel possibilities for the 5-on-5.5" lug pattern are greatly limited.
If you're lowering your truck, the CV front suspension is something worth giving consideration. Overall, it will offer more bang for your buck.
PAR34 07-24-2015 08:00 AM
low boy
https://cimg8.ibsrv.net/gimg/www.for...8f992393be.jpg
https://cimg9.ibsrv.net/gimg/www.for...610ba931cc.jpg
https://cimg0.ibsrv.net/gimg/www.for...a94278516b.jpg
Finished my 72 for now.
DLW-70-F100 08-03-2015 03:11 PM
My fairly original 70' F100, DJM front, axle flip rear..
https://cimg4.ibsrv.net/gimg/www.for...67e2211718.jpg
https://cimg7.ibsrv.net/gimg/www.for...d15e8f4bbb.jpg
https://cimg9.ibsrv.net/gimg/www.for...1bc5936d0a.jpg
nevaplayedk9 08-23-2015 11:16 PM
Originally Posted by DLW-70-F100 (Post 15546071)
what are the wheel/tire sizes?
scurtis3893 09-03-2015 10:48 AM
https://cimg1.ibsrv.net/gimg/www.for...a5844adbaf.jpg
My 68 with CV front with 1 coil cut and 2010 Mustang rear and coils. Fronts up a little do to all the weight not being on it yet. 20" Roush Wheels.
ru67 09-06-2015 09:15 PM
looks good
Originally Posted by tgowers (Post 4624457)
this is my 68 f100. no air bags...that is the everyday ride hieght. my gallery is full of pictures. i hope this helps.https://www.ford-trucks.com/user_gal...id=137829&.jpg[/img]
This is the way i want my 67 im working on to sit. What did you use or do to get the front sitting that low ? looks awesome.
HIO Silver 09-06-2015 09:24 PM
I recall that one has a Lincoln Continental front clip grafted to the original frame. 'Don't recall the what was done to the rear.
ru67 09-06-2015 10:28 PM
using the crown vic front suspension
How much drop are you guys getting using the CV suspension.I have seen were the police inc cars have a 700lb spring rate and the reg CV's have a 400lb spring .To sit a little lower it should work better to use the 400lb springs ?also if they are making the different springs that will help also.I like the looks of the mustang II the way it lets these trucks sit real low its but its out of my price range. Does anyone know exactly how much wider this CV front end is from the frame out to were the the back of the wheel sits against the rotor compared to the original width ?? I have heard they are some wheel size issues using this . Im going to drop my 67,and i want it low just not sure which way to go. Thanks.
nevaplayedk9 01-23-2016 04:55 PM
Originally Posted by fcatoem9 (Post 14624444)
thats exactly what im going for....I just ordered the DJM kit today.
crfly 01-23-2016 08:25 PM
is that a fuel cell poking out under the roll pan? If so, details please.
PAR34 01-23-2016 08:48 PM
fuel cell from atomic fab, they use to sell them on thier web site, but I don't see they do, worth a phone call to them. Fuel Cells & Ice Boxes Photo Gallery - Atomic Fabrications
https://cimg9.ibsrv.net/gimg/www.for...af6a9ca162.jpg
crfly 01-23-2016 08:52 PM
Thanks, that looks really cool. Its on the list now. Great looking truck :-jammin
Bdox 01-25-2016 12:37 AM
Very nice! Looks just like Donna's truck. (She is the Nevada chapter leader.)
nevaplayedk9 02-23-2016 10:53 PM
https://cimg2.ibsrv.net/gimg/www.for...8087a30737.jpg
DJM beams, hanger and shackles
https://cimg4.ibsrv.net/gimg/www.for...1260189f38.jpg
joelb114 07-03-2016 11:08 PM
1 Attachment(s)
Lowered trucks? Mine is lowered a little bit.
72 long to 69 short w/ Jag IFS, EFI, A/C, Explorer rear, etc...
