HELP P1316 code & Runs Rough??
On sat. morning I drove appx. 1/2 mi. parked, came out 5 min. later and started my 2001 F350 SD Diesel W/75,000 mi. and it was running rough and the SES light was on. I changed fuel filt. in the fall and maintain it well.
Pulled the code with my OTC Genisys and came up with P1316 Ignition Diagnostic Monitor Codes Detected. My Alldata dosen't go to 2001 and I have no other info for this truck. I'm thinking I've got a injector gone bad. Any one have any exp. with this that can guide me?? TIA Tommy |
P1316 is a generic IDM code. It means that you have more codes stored inside the IDM itself. The way to retrieve them is to run an injector buzz test.
Since I've never used the Genisys, I have no idea if it's capable of that. Quite a few PSD owners as well as myself use Autoenginuity, which can run a buzz tests and pull IDM codes in a few seconds. If you can't pull the IDM codes at the moment, your best best is to first check the UVC harnesses. They are located in the middle of each valve cover and each face the valley of the engine. You'll either have chaffed wires from a failed harness, or the clip underneath the valve cover popped off. For that you'll have to take the valve covers off and reconnect. They come off surprisingly easy. Hope this helps. |
Thanks Pocket I'll ck if I can do a buzz test tommorrow.
Not to sound stupid but what is the IDM ?? |
Well I started my truck this morning for my drive to work (appx 8 mi. drive) and it was running fine with no SES light, at arround 6 mi. here it goes again missfiring and SES on.
So after work I decided to pull the valve cover's and of course the second one I pulled the connector was backed off, while I had the both cover's off I secured both harnesses inside the cover's. Only took about 2 hrs. . Started good and road tested, runs great. Thanks for the help guy's. Tommy |
Glad you got it back up and running right.
Thank's Pocket.
Just for reference I'll check if the Genisys can do a buzz test. |
Well I checked today and in the "Self Diagnostics" menu with a OTC Genisys here are the test's.
KOEO Injector Buzz Test KOEO Output State Test KOER Self Test KOER Glow Plug Self Test KOER Cylinder Contribute Test KOER Switch Self Test Ran all the test's and all is good now. Tommy |
I think Pocket rates some rep points for that (click the scales on the right upper side of his post).
Great going! |
Great going! Tommy |
