Ignition Switch Terminals
Does anyone know where I can find a diagram showing what each terminal is for on an ignition switch? I know what a couple of the terminals are for, but not sure on the rest. Any help is greatly appreciated. Thanks.
Bill |
Check here for starters, and ignition wiring.
Good luck http://www.autozone.com/servlet/UiBr...3d800ce982.jsp |
That won't help. I have an ignition switch from a 78-79 with no wiring pigtail. Need to find out what all the terminals are for based on how they are labeled. Thanks though.
he means this.
The Switch pin-out. It goes by Vin # for whether it is a 77 or mid-78 + The switches changed design in mid -1978... https://www.ford-trucks.com/user_gal...id=135809&.jpg this one pictured below is for the later design.(the one on the right above) http://www.clubfte.com/users/mil1ion...nFaulttest.JPG https://www.ford-trucks.com/user_gal...id=120398&.jpg |
Mil1ion - So here's the deal. I am installing a Painless 18 circuit harness in my 77 F250 and am trying to figure out which wires to install where on the switch. I have 2 battery wires which I will obviously put on the battery terminals. I will put the switched accesories on one of the ACC terminals. What about my coil wires? I installed a HEI style distributor. And what about the wire that goes from the ignition switch to the "S" terminal on the relay? Should I put that one on the ST terminal on the ignition switch?
