chaparro |
02-08-2007 12:52 AM |
2007 head to head Exp El vs Sub.
Head to Head: 2007 Chevrolet Suburban LT3 4x4 vs. 2007 Ford Expedition Limited EL 4WD
<TABLE class=insettxt borderColor=#000000 cellSpacing=0 cellPadding=2 width=430 border=1><TBODY><TR vAlign=top><TD class=insettxt></TD><TD>2007 Chevrolet Suburban LT3 4x4</TD><TD>Ford Expedition Limited EL 4WD</TD></TR><TR vAlign=top><TD class=deck align=middle colSpan=3>Powertrain/Chassis</TD></TR><TR vAlign=top><TD class=insettxt>Drivetrain layout </TD><TD>Front engine, 4WD</TD><TD>Front engine, 4WD</TD></TR><TR vAlign=top><TD class=insettxt>Engine type </TD><TD>90* V-8, alum block and heads </TD><TD>90* V-8, iron block, aluminum heads</TD></TR><TR vAlign=top><TD class=insettxt>Valvetrain </TD><TD>OHV, 2 valves/cyl </TD><TD>SOHC, 3 valves/cyl</TD></TR><TR vAlign=top><TD class=insettxt>Displacement </TD><TD>325.1 cu in/5327cc </TD><TD>330.3 cu in/5414cc</TD></TR><TR vAlign=top><TD class=insettxt>Compression ratio </TD><TD>9.9:1</TD><TD>9.8:1</TD></TR><TR vAlign=top><TD class=insettxt>Power (SAE net) </TD><TD>310 hp @ 5200 rpm* </TD><TD>300 hp @ 5000 rpm</TD></TR><TR vAlign=top><TD class=insettxt>Torque (SAE net) </TD><TD>335 lb-ft @ 4400 rpm* </TD><TD>365 lb-ft @ 3750 rpm</TD></TR><TR vAlign=top><TD class=insettxt>Weight to power </TD><TD>19.0 lb/hp</TD><TD>20.9 lb/hp</TD></TR><TR vAlign=top><TD class=insettxt>Transmission</TD><TD>4-speed automatic </TD><TD>6-speed, automatic</TD></TR><TR vAlign=top><TD class=insettxt>Axle/final/low ratio</TD><TD>3.73:1/2.61:1/2.72:1</TD><TD>3.73:1/2.57:1/2.64:1</TD></TR><TR vAlign=top><TD class=insettxt>Suspension, front; rear</TD><TD>Control arms, coil springs, anti-roll bar; solid axle, coil springs, anti-roll bar</TD><TD>Control arms, coil springs, anti-roll bar; multilink, coil springs, anti-roll bar</TD></TR><TR vAlign=top><TD class=insettxt>Steering ratio </TD><TD>17.8:1</TD><TD>20.0:1</TD></TR><TR vAlign=top><TD class=insettxt>Turns lock-to-lock</TD><TD>3.0 </TD><TD>3.2</TD></TR><TR vAlign=top><TD class=insettxt>Brakes, f;r </TD><TD>13.0-in vented disc; 13.5-in vented disc, ABS </TD><TD>13.5-in vented disc; 13.2-in vented disc, ABS</TD></TR><TR vAlign=top><TD class=insettxt>Wheels, f;r</TD><TD>17 x 7.5 in, cast aluminum </TD><TD>20 x 8.5 in, cast aluminum</TD></TR><TR vAlign=top><TD class=insettxt>Tires, f;r </TD><TD>265/70R17 113S M+S Goodyear Wrangler HP</TD><TD>275/55R20 111H M+SPirelli Scorpion STR</TD></TR><TR vAlign=top><TD class=deck align=middle colSpan=3>Dimensions </TD></TR><TR vAlign=top><TD class=insettxt>Wheelbase 1</TD><TD>30.0 in</TD><TD>131.0 in</TD></TR><TR vAlign=top><TD class=insettxt>Track, f/r </TD><TD>68.2/67.0 in</TD><TD>67.0/67.2 in</TD></TR><TR vAlign=top><TD class=insettxt>Length x width x height </TD><TD>222.4 x 79.1 x 76.8 in</TD><TD>221.3 x 78.8 x 78.3 in</TD></TR><TR vAlign=top><TD class=insettxt>Ground clearance </TD><TD>9.2 in </TD><TD>8.7 in</TD></TR><TR vAlign=top><TD class=insettxt>Apprch/depart angle</TD><TD>16.7/20.9 deg</TD><TD>24.1/20.9 deg</TD></TR><TR vAlign=top><TD class=insettxt>Turning circle </TD><TD>43.0 ft</TD><TD>43.9 ft </TD></TR><TR vAlign=top><TD class=insettxt>Curb weight </TD><TD>5877 lb</TD><TD>6270 lb</TD></TR><TR vAlign=top><TD class=insettxt>Weight dist, f/r</TD><TD>51/49%</TD><TD>51/49%</TD></TR><TR vAlign=top><TD class=insettxt>Towing capacity </TD><TD>8000 lb </TD><TD>8750 lb</TD></TR><TR vAlign=top><TD class=insettxt>Seating capacity</TD><TD>8 </TD><TD>8</TD></TR><TR vAlign=top><TD class=insettxt>Headroom, f/m/r </TD><TD>41.1/38.5/38.1 in </TD><TD>39.5/39.7/38.0 in</TD></TR><TR vAlign=top><TD class=insettxt>Legroom, f/m/r </TD><TD>41.3/39.5/34.9 in </TD><TD>41.1/39.1/37.7 in</TD></TR><TR vAlign=top><TD class=insettxt>Shoulder room, f/m/r </TD><TD>65.3/65.2/64.7 in</TD><TD>63.2/63.7/67.1 in</TD></TR><TR vAlign=top><TD class=insettxt>Cargo vol behind f/m/r</TD><TD>137.4/90.0/45.8 cu ft</TD><TD>130.8/85.5/42.6 cu ft</TD></TR><TR vAlign=top><TD class=deck align=middle colSpan=3>Test Data</TD></TR><TR vAlign=top><TD class=insettxt>Acceleration to mph 0-30 </TD><TD>3.0 sec</TD><TD>2.5 sec</TD></TR><TR vAlign=top><TD class=insettxt>0-40</TD><TD>4.4</TD><TD>4.1</TD></TR><TR vAlign=top><TD class=insettxt>0-50</TD><TD>6.3 </TD><TD>5.8</TD></TR><TR vAlign=top><TD class=insettxt>0-60</TD><TD>8.9 </TD><TD>8.4</TD></TR><TR vAlign=top><TD class=insettxt>0-70 </TD><TD>11.5</TD><TD>11.1</TD></TR><TR vAlign=top><TD class=insettxt>0-80 </TD><TD>14.4</TD><TD>14.4</TD></TR><TR vAlign=top><TD class=insettxt>0-90 </TD><TD>19.4</TD><TD>18.9</TD></TR><TR vAlign=top><TD class=insettxt>Passing, 45-65 mph </TD><TD>5.0 sec </TD><TD>4.7 sec</TD></TR><TR vAlign=top><TD class=insettxt>Quarter mile</TD><TD>16.6 sec @ 84.4 mph </TD><TD>16.2 sec @ 84.2 mph</TD></TR><TR vAlign=top><TD class=insettxt>Braking, 60-0 mph</TD><TD>138 ft </TD><TD>140 ft</TD></TR><TR vAlign=top><TD class=insettxt>600-ft slalom </TD><TD>55.9 mph avg </TD><TD>54.7 mph avg</TD></TR><TR vAlign=top><TD class=insettxt>Lateral acceleration </TD><TD>0.69 g avg </TD><TD>0.69 g avg</TD></TR><TR vAlign=top><TD class=insettxt>MT figure eight </TD><TD>30.2 sec @ 0.50 g avg</TD><TD>30.6 sec @ 0.50 g avg</TD></TR><TR vAlign=top><TD class=insettxt>Top-gear revs @ 60 mph </TD><TD>1800 rpm </TD><TD>1600 rpm</TD></TR><TR vAlign=top><TD class=deck align=middle colSpan=3>Consumer Info</TD></TR><TR vAlign=top><TD class=insettxt>Base price </TD><TD>$40,760 </TD><TD>$43,395 </TD></TR><TR vAlign=top><TD class=insettxt>Price as tested </TD><TD>$51,320 </TD><TD>$49,685 </TD></TR><TR vAlign=top><TD class=insettxt>Stability/traction control </TD><TD>Yes/yes</TD><TD>Yes/yes</TD></TR><TR vAlign=top><TD class=insettxt>Airbags </TD><TD>Dual front, f/r curtain</TD><TD>Dual front, front side, f/r curtain</TD></TR><TR vAlign=top><TD class=insettxt>Basic warranty </TD><TD>3 yrs/36,000 miles </TD><TD>3 yrs/36,000 miles</TD></TR><TR vAlign=top><TD class=insettxt>Powertrain warranty </TD><TD>3 yrs/36,000 miles </TD><TD>5 yrs/60,000 miles</TD></TR><TR vAlign=top><TD class=insettxt>Roadside assistance </TD><TD>3 yrs/36,000 miles </TD><TD>5 yrs/60,000 miles</TD></TR><TR vAlign=top><TD class=insettxt>Fuel capacity </TD><TD>31.5 gal </TD><TD>33.5 gal</TD></TR><TR vAlign=top><TD class=insettxt>EPA city/hwy econ </TD><TD>15/20 mpg </TD><TD>14/18 mpg (est)</TD></TR><TR vAlign=top><TD class=insettxt>MT fuel economy </TD><TD>15.0 mpg </TD><TD>18.7 mpg</TD></TR><TR vAlign=top><TD class=insettxt>Recommended fuel *SAE certified</TD><TD>Regular unleaded </TD><TD>Regular unleaded</TD></TR></TBODY></TABLE>
