1964 Ranchero rear axle code + weight
Anybody know what this axle tag might mean? Is the 3.50 stamped into the tag my ratio? 8"??
Tag: WCY-F1 3.50 3KC509? I think its a "9" at the end, could be an "8", fighting with a little rust here. ALSO: I need the weight of this vehicle if anybody might happen to know it... Thanks guys, couldnt find this info searching here or the internet... Michael |
if that's the falcon style ranchero, you might find some info on a falcon site - i found some info on mine on a torino site. it didn't have specs for the ranchero, but a lot of the stuff applies. for the weight, i figured:
see what the difference in weight is between a 4-door torino and a 2-door. subtract that difference from a station wagon weight. subtract a little more for the roof and glass in the back of a 'wagon. and maybe that'll be close! someone here posted actual weight from a track scale, which is probably more accurate than published data. i guess i'll find out when i get it to the track! |
Anybody know what this axle tag might mean? Is the 3.50 stamped into the tag my ratio? 8"?? Tag: WCY-F1 3.50 3KC509? These numbers are date & plant code numbers I think its a "9" at the end, could be an "8", WCY-F1 doesn't show up in my Ford parts book. Axles that do show up for the Falcon are: WCY-E = 3.20 > 7.25" RING GEAR WCY-F = 3.50 > 7.25" RING GEAR WCY-L = 3.20 " WCY-M = 3.50 " WCY-N = 2.83 " WCY R = 2.83 " WCY-AA = 2.83 " WCZ--E = 2.80 8" RING GEAR Other ford axles explained. [link:hiqties.hypermart.net/9inch.html|Ford Axle Link] [font color=red]Dennis FTE Assistant Administrator [/font] [link:www.ford-trucks.com/guidelines.html|Club FTE] [link: motorhaven.autoanything.com|How YOU Can Support This Site] http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif [link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"] |
