Welcome Applied Rotor Technology
I'm sure many of you have experience the pulsing stops of warped brake rotors and here's some help from Applied Rotor Technology...
- ART engineers and manufactures high performance brake systems for the racing and performance street markets. - ART utilizes its patent pending process to perform highly specialized cryogenic heat treatment on brake as well as other metal components. - ART custom machines every rotor to exacting specs and tolerances with its HAAS VF-3 Vertical Machining Center (40”x 20”x 25” travel) for multi-axis CNC machining. - ART performs all critical technical and quality assurance work in-house and does not outsource any labor ! - The company distributes OE aftermarket rotors, brake pads, remanufactured calipers, and big brake upgrade kits. |
I have a set on my LD F250 that I installed in 2002 (47K miles ago) and there is no comparison. You won't have warped rotors and you can hit the brakes hard and know they will work. Piece of mind they are.
Welcome! I have heard great things in the SuperDuty forum about your company. I am sure you will get a lot of business from members on this site. :-X22
-Matt :-tap |
Thank you for the welcome
Thanks Matt,
Many of the members here have used our brake kit for years now. In fact, Mark Strickland posted this install way back in August of 2004. https://www.ford-trucks.com/article/...tallation.html |
Great news and welcome!!! :-wink
-Matt :-tap |
ART Rotors, RIGHT ON.
Already got a set on the fronts, 2 years now. Great Brakes! b62 |
