If anything, what would you pick for driving everyday?
I would choose
1979 Ford F350 lifted with 2 1/2 ton axles with tractor wheels n tires and of course the 385 series 460 stroked 'n bored out |
No one makes what I want for a DD- 4-cylinder, manual transmission, rear wheel drive, compact wagon. I want at least 35 mpg, hate front-drive, won't drive a slushbox, and don't honestly need a truck on a daily basis. Further, I want great seats, suspension that handles well, but isn't too coarse for long highway drives, and tons of sound insulation.
Except for not having a back seat, and needing lots more sound insulation, my Ranger with a cap actually comes pretty close... |
Take this engine put it in a 1/2 ton and put a 5 speed in it.
Not much power but look at the torque: PowerTech 3029T Rated Power Intermittent 79 hp (59 kW) @ 2500 rpm Continuous 71 hp (53 kW) @ 2500 rpm Peak Torque Intermittent 200 lb-ft (271 N.m) @ 1800 rpm GENERAL DATA Bore and Stroke - in. (mm) 4.19 x 4.33 (106 x 110) Compression Ratio 17.2:1 Aspiration Turbocharged Length - in.(mm) 28.2 (716) Width - in.(mm) 20.8 (528) Height - in.(mm) 36.5 (928) Just occured to me that alot of torque for a "little" 3 cylinder. |
i think a modern motor in a slick Ford. or a 79 crewcab on an 02 diesel chassis. or even jsut a brand new loaded Ranger
a mazda3...
Hemi 300C.
I wanna big and powerfull sedan. |
I got to test-drive a 300C with the Hemi a few weeks ago, at the Boston International Auto Show. I was very impressed by it, except for the auto-stick transmission. I tried to use it to slow down, and accidentally ended up nearly redlining the engine (shifted to second at 50 mph, somehow). Then, I wanted to go back to regular automatic mode, and couldn't figure out how to do it without shifting to neutral and back to drive. The car reminded me a lot of my friends '00 Caddy Deville- smooth, fast power in car that's more straight-line than anything, but will handle pretty well if you don't mind hanging on through the body roll. Great seats, too.
I'd drive a F350 CC Lariat Outlaw as a daily driver.
A dark blue BOSS 429 mustang.
I want... In order of importaince
New, Domestic, Cheap, Reliable (or easy to fix), rwd, stick, 4 door, small midsize, powerfull, and a decent interior... And I want a nice back seat (srry, had to add that... mine sucks) ~Nate |
My UNI on late modled 4x4. no lift. Just low 4x4 slick
A full size truck that gets 30-40 mpg.
a late 70's early 80s gm big body coupe w/ a vortech 350 or lt1... 20-25mpg, rides like a cloud, and looks half decent... slap some 5 spoke cragars on it and your ready to go.. heh
If I could have anything, I'd take my neighbors project car.
'68 Fastback Mustang, 428 supercharged and a 50 shot, 4 speed manual, 4.10 rear end. |
