Ford Truck Enthusiasts Forums
-   6.4L Power Stroke Diesel (http://www.ford-trucks.com/forums/forum169/)
-   -   6.4L Diesel: 6.4 Tech Folder (http://www.ford-trucks.com/forums/533835-6-4l-diesel-6-4-tech-folder.html)
kw5413 10-04-2006 11:05 PM
6.4 Tech Folder
Ford OBD-II Diagnostic PDF Trouble Code Definitions
6.4L BIBLE Powerstroke 6.4L manual
Thanks, Brickie
Diesel Technician Society Tech Publications
Thanks, Crazy001
Intercooler Modification Installing a drain
Thanks Hardrock_F250
HIGH IDLE MOD Upfitter switch for High idle
CJ4 Rated Oil, From API...SeePost # 19
http://www.ford-trucks.com/forums/53...ml#post4013781
Special Thanks To mrxlh
Particulate Filter Info
http://www.ford-trucks.com/forums/50...lter-info.html
Breaking in a diesel
http://www.ford-trucks.com/forums/23...the-6-0l.html?
Cold Weather Belt Chirp
Ford Truck Enthusiasts Forums - View Single Post - Tsb 07-23-9
Venturi T Installation
http://www.ford-trucks.com/forums/77...tallation.html
Thanks, Caprang
Answer to Job Build Numbers
http://www.ford-trucks.com/forums/81...d-changes.html
6.4L DIESEL ENGINE TECHNICAL SERVICE BULLETINS
TSB 07-8-9 Lacks power, leaks oil, fuel
TSB 07-4-11 REGENERATION FUNCTIONAL CHARACTERISTICS
TSB 08-25-9 VEHICLES BUILT BETWEEN 1/3/2008 AND 9/15/2008
TSB 08-28-1 Hesitation in rainy weather
TSB 07-23-9 Cold Weather Belt Chirp
TSB 08-19-5 6.4L TICKING / TAPPING NOISE
TSB 09-23-1 6.4L DIESEL ENGINES - REPEAT RADIATOR LEAK - BUILT ON OR BEFORE 9/14/2009
TSB 11-6-6 RADIATOR LEAKING COOLANT
6.4 PowerStroke Bulletins
6.4 PowerStroke bulletins
View Original Window Sticker
http://www.ford-trucks.com/forums/10...w-sticker.html
PCM Flash Recall 11B23
Information and letter
Thanks, Eric326
6.4L Head Gasket and High Pressure Fuel System How-to thread with pictures
Thanks, vloney
Fan Stator Mod to facilitate belt changes
Thanks, dlibson
Maxium4x4 07-06-2009 08:26 PM
Torque Charts, Wiring Diagram, Diagnostic Codes
Look at what I found :) and just in case I saved it also.
http://www.fordtechservice.dealercon...que_Charts.pdf
