Sandblasting in Chicago burbs (west) ?
Hi - Looking for a sandblast / powdercoat shop out in the western burbs - Thanks!.
There's a good shop in Delevan, WI if anyone's out that way - they did my frame and axles. They were planning on adding acid dipping too... |
Are you looking for a place or advertising ? If you are looking then why wouldn't you reuse the place in Wi. ? Or are you looking for something closer cause if you are depending on the size I know a guy in Dekalb.
There's a good shop in Delevan, WI if anyone's out that way - they did my frame and axles. They were planning on adding acid dipping too... your profile says WI and you are a WI chapter member Did you move to IL? I am out in the far west suburbs |
