code p1780
does anyone know what might cause this code. thanks
What year is the truck, and which engine?
P1780 - Transmission Control Switch Out of Self-Test Range During KOER self-test the TCS has to be cycled, if not cycled a DTC is set. Possible causes: l TCS circuit short or open l Damaged TCS switch l Damaged PCM |
sorry its a 1999 3.0
The Transmission Control Switch is the button at the end of the shift lever on the steering column.
thank you so much
