Thinking about makeing bio diesel
Well guys, I have had my 01 7.3 diesel for about a week now and I have been researching bio diesel alot today. I think i am going to start building my set up soon to start makeing it, but I am still unclear on a few things. I pretty much understand the whole processing tank and wash tank concept and how to make one. I am haveing trouble finding good info on the net that explains how I do "titrateing". Also, is this something that would be safe to set up in the garage or am I going to risk a fire by doing this. One of my biggest concerns is a bad batch. I am afraid that if I make a bad batch or do something wrong I could cause damage to my truck, what ways are there to test the finishsed product and be sure it is correct?
Lastly, what advice can you guys give me on obtaining the cooking oil? What sources do you use? Will any used cooking oil work? how do you transport the oil home? thanks |
Lastly, what advice can you guys give me on obtaining the cooking oil? What sources do you use? Will any used cooking oil work? how do you transport the oil home? thanks FABMANDELUX. :-X25 :-fire |
Originally Posted by fabmandelux
Welcome to FTE :-X25 And welcome to our small band of homebrewers here:-D If you haven't found it yet, start here first, it will explain titration, and everything else you need to make good bio: http://www.biodieselcommunity.org We're all learning here, so don't be afraid to post any questions, we'll try to find the answer for you.
http://video.google.com/videoplay?docid=457773184300286737&q=biodiesel
After watching that episode of trucks one more time it leaves me with a few more questions. With the setup he used he never had to heat it, what does the heating of it do and why doesnt the $4k set up he used have a heater? Also the tank he used was tapered at the bottom. Useing a water heater tank wont their be problems with getting the by product with the diesel? Since the bottom is flat and all. |
After watching that episode of trucks one more time it leaves me with a few more questions. With the setup he used he never had to heat it, what does the heating of it do and why doesnt the $4k set up he used have a heater? Also the tank he used was tapered at the bottom. Useing a water heater tank wont their be problems with getting the by product with the diesel? Since the bottom is flat and all. The cone bottom tank CAN make it easyer to remove the glycerol, BUT if you use NaOH and wait to long.....................you get a hard lump of glycerol in the bottom of the tank with no easy way to remove it, NOT GOOD. The reason there is no heater in the tank is because IT'S PLASTIC! If something goes wrong [see Murphy's Law ] you will have a huge mess on your floor, besides the potential for a nasty FIRE. The use of water-heaters has it's own set of problems, You cannot see the reaction, if it's cold you have to preheat and clean the oil before you try to put it in the 3/4" fill hole. This is why I use my own design "open" style processer. Have a look in my gallery and see what I use for a processer. FABMANDELUX. :-X25 :-fire |
Stacie left out a bunch. The Fuelmeister is an overpriced bunch of junk, IMHO. The operating instructions tell you to pre-heat the oil BEFORE you put it in the system, but with uninsulated plastic tanks, the temp starts dropping right away. Temperature is very critical, the lower the temp the longer you have to mix!
Just be very carefull if you use NaOH, the glycerol turns to a solid below 100 deg F:-X16 For titration info: http://journeytoforever.org/biodiese...2.html#titrate
Just be very carefull if you use NaOH, the glycerol turns to a solid below 100 deg F:-X16 For titration info: http://journeytoforever.org/biodiesel_make2.html#titrate
Useing a water heater tank won't their be problems with getting the by product with the diesel? Since the bottom is flat and all. As far as not getting ALL the glycerin out is concerned, the washing takes care of that. How effective my heater is at draining from the bottom will probably be the deciding factor in whether or not I continue to wash my fuel. |
Originally Posted by Dave Barbieri
I started studying the bioD thing over two years ago. A year ago January, I bought Maria Alovert's book(let) that covers the specifics on making bioD. I had planned on building an Appleseed Converter and trying this stuff out. Well, life happens, and I finally got started on the the sucker last Easter weekend. Got it finished last week, and started my first batch last night. (I used the famous Fabman BioD Recipe.) I heated my oil for several hours, and then added the methoxide mixture. I use a reinforced nylon hose for my pump outlet to the top of the tank, so I can obsereve the reaction. Since I was using brand new oil for my first batch, the oil was pretty clear. When the methoxide hit the pump, the mixture turned foamy white. I kept the heating element on (the thermostat is set for 130 degrees), and let the pump run for two hours. Shut it down last night before going to bed. This morning, I went out and drained off the glycerin. First try, before church, I drained off just over 3 gallons of dark, tea-colored liquid. (still kinda warm) Now I'm headed back out there to crack the drain and see if any more dark stuff comes out, or if it's all clear. I plan to wash this batch twice and check the result. Fabman is one of many successful bioD producers that choose not to wash their bioD. I figure I'll try one batch as washed, and one batch as non-washed and see how things look.
So in other words if I let whats in the tank get bellow 100degrees part of it will turn solid? If I accidently let it turn solid what can I do about it?
Yes, the glycerol will turn solid in the bottom under your biodiesel:mad:. Use KOH instead, it stays liquid to about 0 deg F:) There are several other concerns with a closed system, #1. If you have water in your oil and don't get a reaction you won't know it because you can't see it. With an open style, you can see the incomplete reaction, and can add more KOH untill you see the reaction complete. #2. If you "wash" in the same tank as you process in, the remaining water in the bottom will contaminate the next batch. Any water in the reaction will KILL IT, so you've got another bad batch.
As far as not getting ALL the glycerin out is concerned, the washing takes care of that. How effective my heater is at draining from the bottom will probably be the deciding factor in whether or not I continue to wash my fuel. Also, try heating to 145-150 deg F. If you only heat to 130 it takes longer to react, and putting in room temp Methoxide will lower the reaction temp further. FABMANDELUX. :-X25 :-fire |
I had planned on useing a white plastic 50gallon drum to build a wash tank, so that wont be an issue. What is KOH apposed to glycerol? I was going to use lye (such as red devil type stuff) and methonol (raceing fuel)
Lye is a generic term, and can be either KOH [Potassium Hydroxide] OR, NaOH [ Sodium Hydroxide]. KOH mixes easyer, produces less fumes, and the glycerol produced is a liqued to about 0 deg F, making it far simpler to remove the methanol from.
