Lowering Question
Ok I have an 03 lightning so far stock with 14k just put on. I am looking for the best handling suspension. I am after more track worthy not looks or fomfort (not that I want to ride on a rock). I am not sure if I am going to stick with the stock 18's or go to a 20 but only want to fill the fenderwell proportionally. Again this is more for close circuit use not drag use. Thanks for any help.
STEEDA makes a verry good kit to lower the rear its a axle relocation lowering kit it will lower the rear 4 "part nomber 555-8800 go to www.steeda.com
ART~~~ |
You may also want to look at Hotchkis Suspension. They have a very good reputation amongst the Lightning crowd, and they offer a Total Vehicle System that has everything you'd need:
http://www.hotchkis.net/cgi-bin/EDCs...03%20Lightning |
I highly recommend the hotchkiss, the guys over at SVTperformace.com speak very highly of it
Originally Posted by donyboy1
I went with eibach 2/4 lowering has new rear springs etc
Hey
the eibadch springs are stiff enough I guess so it rides a little rough from stock but not bad the kit was soemwhere around 600.00 i paid less you can frind the kit a several retailers if i do this again will wait and air bad for more drop just for the looks hope this helps L don |
Hey
the eibadch springs are stiff enough I guess so it rides a little rough from stock but not bad the kit was soemwhere around 600.00 i paid less you can frind the kit a several retailers if i do this again will wait and air bad for more drop just for the looks hope this helps L don What do you guys think? |
