can anyone help a new guy with explaining the timing adjust procedure
I have a 1976 ford ranchero |
Welcome to the site :)
Please post a new topic (your own thread) rather then placing it in someone elses off topic thread. I'll get a mod to move it out on its own. |
Hello- Welcome to FTE! I have Split and moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun! :)
Probably the easiet way aside from using a timing light, is to use a vacume guage. Loosen the set bolt located at the base of the distributor & slowly rotate the distributo until you get the highest vacume reading. drive the vehicle with the ac on & check for pinging (detonation), deduce the timing about 1/16 of an inch until the pinging is not heard.
Adjust Timing
My method is way more complicated than that.....Start The motor, Hold the Brake, Put it in gear, Floor the gas, Adjust the distributer till it (knocks)(pings) Retard the dist till it stops, tighten the bolt!!!!! Then get a timing light and adjust till right!!! I have been doing it this way for 30 years and it still works.........
the highest vacuum reading will be WAY too far advanced. just get a timing light, the cheapest one you can find will work.
as far as procedure, remove the air cleaner and plug any vacuum hoses that may be disconnected(golf tees work real good for this). disconnect and plug the vacuum hose(s) from the advance can, if there are 2 don't get them mixed up! loosen the distributor hold-down bolt and leave it snug enough to hold, but able to turn the dizzy. connect the timing light to the + and - of the battery and the #1 spark plug wire. clean off the balancer so you can see the marks and the pointer well, you can use a dab of white paint or such to highlight the desired setting on the balancer. start the engine and shine the light at the pointer. turn the dizzy to align your mark at the desired setting to the pointer. shut of the engine and tighten the hold down bolt. start the engine and verify that the setting did not move while tightening. shut off the engine and reconnect the vacuum hoses and disconnect the timing light. replace air cleaner and reconect vacuum hoses. |
