Location of delta P switch ?
Re troubleshooting brake warning lights . 96_4wdr posted this:
"To see if the Delta P switch is the cause of the illuminated warning lamp(s), disconnect the two-wire connector (on the Delta P switch) and jump the two wires together. If the light sequence returns to normal, the Delta P switch is the cause. " Can someone tell me where this switch is located on a 95 AerostarAWD? |
I believe it's right on top of the proportioning valve, which is mounted on a bracket right under the master cylinder.
Ok Thanks I'll check that out .
The jumper put the lighhs out. Thanks for directions. Off to the wreckers.
