superchip codes P1211/P0603
Can anyone give me the dumbed down answer to these two codes, I have the superchip manual and it gives P1211: ICP not controllable-pres above/desired. P0603: Internal Ctrl Mod KAM error. The truck is a 03, 7.3L auto running on max setting with pryo, boost and trans gauges and a 4" exhaust.
I guess the real question is am I damaging the truck when the engine light comes on. (Pryo stays resonable cool, 425c post trubo) Thanks Mick |
just about anytime you add a tuner or programmer to the 7.3 psd those codes will come up...dont worry about them as long as the truck is running ok. simple enough :)
Neither one are a problem, both are set by the programmer. No damage is being done.
800f post turbo is not bad, what's the boost doing when the CEL comes on? |
Threads merged.
