292 Y Block
Hi this is Ken.I have an old 292 Y Block Ford motor with the Forged Crank,Rods and pistons..It's in decent condition..I was wanting to know if they are worth rebuilding ?? The crank ,rods are in perfect condition..The bearings look like new..There was some water damage in a couple of the cylenders...I could probably hone the cylenders out enough to re ring it..Is it worth my time and money to fix ?? Any information will be greatly appreciated.......Thanks.....
Hello & Welcome to the site!
This forum is for introducing yourself :) Here is a direct link to the Y block forum. https://www.ford-trucks.com/forums/f...play.php?&f=56 Enjoy the site....It's huge ! |
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
Thread moved to Y-Block forum. See ya on the boards! :-wink -Matt :-tap |
lilKenny, also welcome to the site.
If you look around on this forum you will see that we like Y's! If you rebuild the 292, what would you put it into? That could help with the "is it worth it" question. The Y-blocks now have more aftermarket parts than ever before, but still not nearly as many some of the other motors. How did you determine you have a forged crank? Have you checked out www.ford-y-block.com to ID the year of the motor? Mike |
Thanks I appreciate the help...I have put it up for sale Here under 1964 292 Ford Y Block.. Forged Crank , Rods and Pistons...Thanks again......Ken....
welcome
hi and welcome yes the 292 is worth keeping :-X22
Hi..Thanks for the info...I have posted it for sale here on this web site...Thanks again.......Ken.....
1966 Ford 1/2 ton I Beam Front Suspension
Hi..Im looking for the Front left side of the 1965 / 66 Ford twin I beam suspension..The actual I beam..I'm restoring a 66 ford 1/2 ton pickup and the front suspension is bent from a kid hitting the ditch with it...Any information would be greatly appreciated....Thanks for your time...Ken....
You would have better luck posting what you need over on the 61-66 forum.
Mike |
