brake upgrade, whats the best
looking to upgrade the brakes on my 02 F350 psd long bed.
right now i have a bit of warped rotor wobble in the stering wheel when i press on the brakes. has anyone installed performance brakes on their one ton? i read about power slots but they dont make one ton rotors? well they dont show any on the web page. |
Good question. Might consider moving this to the Super Duty Forum for a better response. Just an idea.
It seems every discussion on the Superduty forum relating to brake upgrades rave about the ART rotors. If you do a search I'm sure you will find the info you need.
Tony |
one question. what do you plan on doing with the truck? because that makes all the difference.
well in the future, next year or two i plan on purchasing a cab over camper, then some day a boat and maybe even a trailer to haul around a couple of sleds or even some wheelers. just preping up right now for future purchases.
i have purchased a set of power slots and hawk pads, read a lot of posts and it seems that they were a good up grade. |
if you all did not know this allready, Alaska is not part of the continental United States, the free shipping does not apply to Alaska.
wellin that case i would get some cross drilled or slotted rotors that way the gas from the heat generated will escape easier and not case any fade i would also look into get some bigger rotors and calipers more force and rotor wont heat up as much.
the ones i ordered are slotted,
they are supposed to disapate heat better and prevent warping. |
