driveshaft wanted
Looking for a driveshaft that will connect an early c4 auto trans (dip stick in pan) to a differential in a 1981 f100 swb. Is there such a critter? It has an I 6 engine.
I live in N>E> Ohio, thanks for any help 1981ford |
Hi and Welcome to FTE! :)
There is an Ohio Chapter (located here: https://www.ford-trucks.com/forums/f...splay.php?f=91 ) that may be able to help you out. Maybe you can find someone a little more local. -Matt :-tap |
Welcome to FTE!
Moved to proper forum. You can go to a driveline shop and they can make any driveshaft you need. |
Hi and welcome to the Ohio chapter, your post was moved here inorder to help you better.
Heres a link to a search engine for some salvage yards that might help you find what your are looking for. http://car-part.com/ And maybe another member here might even have the part your looking for. |
Thanks for the tip and putting me in the Ohio forum.
1981ford |
