disable seat belt alarm
does any one no how to disable the seatbelt alarm on a 2004 f-150 heritage??
Its in the owners manula under belt minder I think its called.
ViperFX4 |
In & Out
If it is like my truck 04FX4 (scab) you must:
do i have to run around the vehicle 3 times after that? just kidding. thanks for the info, i'll let you know how it turns out
Does disarming the seatbelt alarm effect the passenger air bags? Just curious.
OK thanks for the info.
Along with those instructions you have to put your emerg brake on and it`s nine times to buckle and unbuckle.Page 117 or 118 in the book.
Jim........ |
I completely thought you guys were screwing with me. but it does work, for the heritage its a little different (page 80 of the manual) . thanks for the help. bing, bing, bing, bing, bing
I've found the easiest way to turn off the "ding" is to:
Put key into the ignition - Actually start the engine - Fasten the seatbelt - Put truck in drive - Start driving - amazing - no "ding" You've just successfully disengaged the alarm without wasting your Saturday morning!! |
OR, you can do like me and turn the "beltminder" on and off for both the drivers seat and passengers seat, (repeatedly) and still not get the seat belt chime to sut off. I know I must be doing it right because I can get the single burst of air bag icon flashes (thats off) as well as the double bust of flases (thats on), but no matter what that lovely chime continues to do its thing! Take your choice waste your time or not!
Auto Locks
A little off topic but similar.. Does anyone know how to disable the doors from auto locking?
XLTBryan |
Originally Posted by F150lady
Nice response, very insightful answer, if you can't say something helpful then shut the #@&! up.
:-X15 :-roll |
XLTBryan 1. Start in the truck with all doors closed and the key turned off. 2. Put the switch in the on position and press the door unlock button 3 times. 3. Put the switch in the off position and press the door unlock button 3 times. 4. Put the switch in the on position, you should hear a quick note from your horn. 5. Press the door unlock button 1 time then press the door lock button 1 time. 6. You should hear a short note from your horn indicating that the auto-lock system is disabled. If you hear a short note then a longer note from the horn then the auto-lock system has just been enabled. 7. Turn the switch to the off position. You will hear a short note from the horn to let you know that the system has been changed. These steps should be done within 30 seconds in order to properly activate or deactivate the feature. |
