Originally Posted by Btravelen
The GM has the Allison which is a plus. Is the Torqueshift available with the 6.8 this year?
Originally Posted by car
Hey Ken 04 !! In responce to my thread, what do you mean by " the v10 will do half 0-60 what the 8.1 will do" and " the other con, i'll get back to you after you submit your qualifications to the FTE" ??????????? Did i miss something??
No worries bud, it's all in good fun, take care, Ken :-X25 |
Originally Posted by V10KLZZ71S
496'S are some awesome marine engines, not quite sure why Chevy's dominate the marine market,because Ford makes very good marine engines also, but they do.Ford power can make even a V10 a marine engine.Now that would make a good ski-boat powerplant.I have heard that the 8.1's have an oil consumption problem,but since I have never owned one,cant say if that is true or not.I've always believed that the V10 with it's 72 degree firing order compared to a 90 degree firing order, the 6.8 is making power at a faster rate,meaning it has 2 more cyl's firing within the 720 degree cycle than a V8.So it's rate of delivery is better.Just like a 2 cycle makes power twice a fast as a 4 cycle,not saying it makes more power,just at a faster rate.
Deep skirted blocks of today are copied of the old 406 and 427 Ford side-oilers of the '60's with cross-bolted main caps.
As far as Marine aplications I would rather have the 8.1 over the V10. More easily upgraded for more power, it sounds much better and more displacement, which you need beacause a boat is under load all the time..
Originally Posted by ken04
I don't know how closely related the 8.1 design is to the smaller LS-1/LS-6 line of engines, but I had the chance to see an LS-1 come apart the other day. And I tell you what, GM has pretty much got that design down to a science. Deep skirted block, 6 bolt main caps, a bunch of stuff that even a Ford blue-blood like myself was impressed with (it did have a spun rod bearing, but it was in a street class drag car). Ford has jillions of engines running around in boats, from the 2.3 four all the way to the 7.5. Butyou raise an interesting question, why isn't the 6.8 in marine applications ? Is it too long ? All the mod motors from Ford don't seem to be in marine power, and I just went to the boat show 2 days ago. The 6.8 V-10 is used in alot of generators, I wonder why the absence of marine applications ? Ken :-huh
The 8.1 is a direct relative to the 454 so it does not share the deep skirt, cross bolt design of the GM LS motors. But remember that the Ford modular motors also have the deep skirt cross bolted mains (4 or 6 depending on the motor) and it was out 5 or so years b4 the LS motors. Some of the FE's had cross bolted mains also.(like wildman said) As far as Fords being big block marine motors I think the 6.8 is cubic inch challenged for boat work. Currently the Lightning motor is available in the Ski-Natique. Off topic but a coool marine motor is the Illmor Viper V10. A very understressed 600Hp/torque low revving monster. |
I think one reason more boats tend to use chevy motors over fords is torque vs horsepower. A truck needs the low end torque to do what it does best; pull loads at lower RPM. A boat needs high horsepower at higher RPMs; where it normally runs. Normally you see Ford engines building a better torque curve than chevy, but you see chevys running higher horsepower. That's also why you see diesels in larger, cruiser type boats. Pleasure boats need RPM to go fast. Only one gear means you need rpm and horsepower more than monster torque.
Look at the advertising campaigns of both companies. Chevy likes to tout its horsepower numbers in all its ads, while Ford is always showing something mongoso getting pulled around. That's why you don't see diesels racing NASCAR and you don't see gassers pulling semi's. Horsepower for show, Torque for go. That's my 2 cents. |
No offense bfr250 but you must not own a boat or at least not a real sport boat. Its all about torque and those twin 496's i own have a gob of it. To move MASS thru WATER you must have torque and lots of it. Boats dont have wheels like trucks and cars. V10 is a great motor no doubt and I am looking at a 2005 to pull my rig but the GM big block in whatever form is still the king in the marine world. The new Illmore is a challenger but not a production motor by any means at this point.
Well Ken 04 we're glad you explained your actions as otherwise we wouldn't of had a clue what you were talking about . You are sooooo funny, Oh!! And lets not forget, my hero also!!! jim robbins
i for one own a 2003 chevy suburban 3/4 ton 4x4. it has the 8.1 3.73 gears with the 4l80 trans. this sucker is a pulling monster. i pull a 28' forest river toy hauler loaded weighs 10,000lbs. it has the pre 04 engine ratings... 340 hp 455 torque. for 04 chevy lowered all numbers 8.1 is 320 hp 440 torque. (something with smog i believe). i also have been told (gearheads please chime in) the 4l80 has less drive line loss than the allison and the torqueshift also has less drive line loss than the allison. this could be a reason the v10 is faster as some of you have mentioned...
it uses about 1-2 quart of oil per 3000 miles. empty i get 12 city 17 hwy.. pulling i get 7-9 mpg... thanks, eric |
